      04-13-2021, 06:23 PM   #1
Kuch335
2007 335i E92
Kuch335's Avatar
44
Drives: 2007 E92 TiAg, 2011 X3 35i
Coolant level / Overheat : Code 20a901 : But temps are fine..
I've had an engine overheating light come on a couple times in the last few weeks. 2011 X3 35i, the code is 20a901 which states coolant level. Level is fine and temps are well below 250. Any ideas? Is the coolant reservoir supposed to have a little floating level indicator? My 335i does but nothing in the X3.
Thanks!
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
      04-15-2021, 07:34 AM   #2
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Thanks!
what coolant temps are you seeing?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      04-15-2021, 10:47 AM   #3
Bdavi011
Drives: 2013 BMW X3 3.5i
Maybe water pump or thermostat are on the way out and the car is warning you that the temperature has increased past a safety point?
Coolant reservoir has a non moving level indicator inside of it. Have to look inside of it and you will see something that shows min/max.
      04-16-2021, 08:57 PM   #4
Kuch335
2007 335i E92
Kuch335's Avatar
44
The dash temp always stays between 195 and 250, never even reaches 250. Occasionally the radiator fan will run non stop and it will get down to the 195 mark. Drove around quite a bit today and got no codes and no fan running.. gremlins.. Stopped by the Porsche dealer, they had an Audi QS5 for 26k, first I've seen one, pretty nice, tempted, lol.
      04-16-2021, 09:38 PM   #5
pungo
pungo's Avatar
The dash gauge is oil temp, not coolant temp
Connect a proper scan tool and check for errors and real coolant temps.
Or use the hidden menu to show coolant temp.
BTW, if coolant temp is well above 230F, stop driving the vehicle and have it diagnosed.
      04-17-2021, 06:00 AM   #6
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
that's not coolant man. you prolly have a legit issue here. you need to get it checked.
