      04-11-2021, 11:04 AM   #1
turbo4
markster
Drives: 2016 X3 xdrive28d
recommended break kits
I have 2016 X3 diesel and I am going to have to change my breaks in next few months. OEM bmw x3 breaks are not that great, soft and it takes lots of pedal travel to start breaking.
When I first got the x3, these were full of rust. What would you guys recommend for the kit, break pads and rotors? I don't like the calipers being rusted as they are but it would cost a lot to replace them as well.
      04-11-2021, 04:12 PM   #2
Blaster400
Blaster400's Avatar
127
Drives: BMW X3 35i, Porsche Macan S
https://www.fcpeuro.com/products/bmw...4106879122ktfr
      04-11-2021, 07:34 PM   #3
Bdavi011
Drives: 2013 BMW X3 3.5i
I have Zimmerman and Akebono combo on my X3 35i. I recommend it. No issues with braking. Barley any brake dust and after 15k miles barley any wear.
      04-11-2021, 11:46 PM   #4
turbo4
markster
Zimmerman and Akebono combo seams like a very good choice. Both of your, thank you for suggestions.
      04-12-2021, 09:19 AM   #5
Wgosma
Drives: 2012 F25 X3 28i (N52)
You will get a bit better initial/cold bite with stock BMW pads compared to the ceramic pads, this is why I use the stock pads, but dust generation is much greater w/stock pads.
      04-12-2021, 09:23 AM   #6
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
Ceramic pads typically last longer, create much less dust and result in less to fading under repeated use.
These are all good reasons to "upgrade" to ceramic, IMO.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
      04-16-2021, 06:15 PM   #7
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
I don't have any brands to recommend, but would suggest ceramic pads because they produce much less brake dust and are much kinder to rotors. The OE semi metallic pads typically score rotors beyond repair and it's rotors that are the expensive part of a brake job. Like you, rust (from road salt) is always a problem where I live, so coated rotors can reduce this in areas not swept by pads.
      04-16-2021, 06:18 PM   #8
383vett
383vett's Avatar
Another recommendation for ceramic BRAKES. Hate the dust and have them on all my cars including my Z06.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      04-19-2021, 10:24 AM   #9
FranzX3M
Drives: '13 X3M
EBC Red are good ceramic pads. Better than stock performance and low dust. Long life as well. For rotors, Zimmerman.
      04-19-2021, 07:55 PM   #10
okayr
okayr's Avatar
Drives: 2014 BMW X3 xDrive28i
Just did front and back with Zimmerman/Akebono kit from FCP. I couldn't really tell too much of a difference in stopping speed but I have noticed less dust.
I agree that the brakes are not really the best. I did the DSC reset to try to stiffen the pedal. It helps some initially but after a few days of driving the pedal feels pretty soft again. If you're interested this is what I followed:
      04-20-2021, 11:54 AM   #11
FranzX3M
Drives: '13 X3M
I am much happier with by brakes now after installing braided brake lines, EBC Yellow pads and changing the brake fluid. Stopping performance and pedal feel is much improved. The EBC yellow pads are dusty but that is the price for higher friction and initial bite. People often overlook brake fluid maintenance and must be done anyways if changing the brake lines. I did it myself and it is not difficult but takes some time.
      04-22-2021, 08:51 AM   #12
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
+1 on the brake fluid flush. I had it done for my X3d recently before a longer trip and the braking feel is much better.
It's one of those things we tend to overlook but it makes a big difference.
Tags
breaks
