05-24-2013, 09:42 AM | #1 |
Rep 2
Auto shutoff
I am considering having the dealership undo my 2013 X3's automatic engine shutoff at idling. I don't think it is helping my gas mileage, can't imagine its not hurting the life of my starter, and find it unnerving, especially at night (lights flicker) and when its raining (wipers hiccup).
Any thoughts? |
05-24-2013, 09:47 AM | #2 |
Rep 47
Drives: 2014 x3 35i
I don't like it either and feel the same. I have a switch next to the start button on our 2014 so we do not need to reprogram the fob. Sounds like prior years didn't have this?
Regards,
Bob |
05-24-2013, 11:16 AM | #4 |
Rep 394
The cut off button works. If you don't like the engine shutting off, just disable the feature. Also, the starter was seriously beefed up to handle this added load. I personally like sitting at a red light and the car not running. Every little bit helps.
05-24-2013, 11:18 AM | #5 |
Rep 394
Not so. The eco pro mode that was introduced in 2013 along with the new 4 cylinder motor on the 28i's came with the auto start/ stop feature along with the kill switch next to it. It is fully defeatable for those that don't like it.
05-24-2013, 11:21 AM | #6 | |
Rep 2,323
05-24-2013, 11:35 AM | #7 | ||
Rep 47
Drives: 2014 x3 35i
Regards,
Bob |
05-24-2013, 01:11 PM | #8 | |
Rep 2,602
05-24-2013, 02:42 PM | #9 | |
Rep 2,323
05-24-2013, 03:51 PM | #11 |
Rep 5,448
I don't mind it on my 14 35i, it is set by default to remember the last setting, where before the 14 model year it was set to on by default and would turn back on when you turned off the car. The possible settins are on by default, off by default or remember last setting.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-25-2013, 07:52 AM | #13 |
Rep 181
You can also prevent auto start/stop from engaging at a stoplight as follows, even if the system is activated: Press the brake hard when you come to a stop, then ease up on the brake pressure a little (but not enough to roll forward.) The engine will not stop at that light. Try it, it works!
05-25-2013, 10:59 AM | #14 | |
Rep 2,323
05-25-2013, 02:35 PM | #15 |
Rep 5,448
+1 I cannot get that to work no matter how hard I try, just shuts off anyway.
05-26-2013, 08:08 AM | #17 |
Rep 5,448
I leave mine on auto all the time, still shuts off at lights, but sometimes turns back on before the light ends - maybe that will change when it gets hot in the summer here and the AC needs to run all the time?
05-26-2013, 08:10 AM | #18 | |
Rep 2,527
05-26-2013, 08:57 AM | #19 |
Rep 2,323
05-26-2013, 03:22 PM | #20 |
Starfleet Command
315
Rep 785
big +1. totally annoying and very abrupt if using auto hold and engine shuts off using Auto S/S.
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
05-26-2013, 05:49 PM | #21 |
Rep 1,797
It's called ASS for a reason
You can also have it disabled by: Transmission in Sport Mode & Eco in Sport Mode That's the way I like to drive this little N20 anyways so it's perfect for me!
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
