09-11-2017, 06:43 PM | #1 |
Rep 35
Corner Lighting?
Hi Everyone,
I didn't come across a clear post on if corner lighting is possible on a '17 X3. Some say yes, some say maybe... some say no. I tried to code my X3 (it has halogens with LED fog lights) with the parameters below but all it did was disable my high beams . Has anyone had any success or do I have a coding mistake? FRM --> 3080 --> C_CLC_ENA --> F25Enable FRM --> 3080 --> C_BLC_ENA --> F25Enable FRM --> 3080 --> Lamp_map_para_satz_01 --> BV-F025_WERT02_Corneringlight-UBER-NSW FRM --> 3080 --> Lamp_map_para_satz_02 --> BV-F025_WERT02_Corneringlight-UBER-NSW FRM --> 3080 --> U_EFF_CL --> wert_07__12,8V Any help is appreciated! |
09-12-2017, 09:36 PM | #3 |
Rep 35
Thanks for the response Almaretto. You helped clarified. This cannot be achieved with adaptive headlights. This can be found at the link below:
http://www.bimmerfest.com/forums/sho....php?t=1085145 |
09-12-2017, 10:04 PM | #4 | |
Rep 8,364
09-13-2017, 10:11 AM | #5 |
Rep 746
Drives: X3 20d Xline Melbourne Red
I have cornering lighting on my X3 through the Foglights
It also has adaptive lights ... however mine is in the UK and I am aware that US Federal law prohibits the full adaptive experience we get in Europe .. so that may be an issue for you
Gone: E90 crimson red/black
Gone :X1 23d Msport manual, Space/Beige Pro Nav, Adaptive zenons, privacy glass, 18's, ext storage, Current: X3 20d Xline auto, Melbourne/Beige, Sport seats, Viz pack, heated steering wheel, Folding mirrors, privacy glass, luggage net, pro nav Current: E85 Z4 3.0si roadster titanium/Syrah individual Current: F31 320d touring black/black work hack |
09-15-2017, 06:20 PM | #10 |
Rep 8,364
09-15-2017, 09:17 PM | #11 |
Rep 35
Where did I go wrong in my coding? I coded these however it didn't do anything but disabled high beams.
FRM --> 3080 --> C_CLC_ENA --> F25Enable FRM --> 3080 --> C_BLC_ENA --> F25Enable FRM --> 3080 --> Lamp_map_para_satz_01 --> BV-F025_WERT02_Corneringlight-UBER-NSW FRM --> 3080 --> Lamp_map_para_satz_02 --> BV-F025_WERT02_Corneringlight-UBER-NSW FRM --> 3080 --> U_EFF_CL --> wert_07__12,8V |
09-15-2017, 10:47 PM | #12 | |
Rep 8,364
09-16-2017, 11:03 PM | #14 |
Rep 35
Thanks @Sephanite that would be great if you could do that. I've been struggling with this for quite some time.
04-25-2018, 06:31 AM | #15 |
Rep 451
Drives: 2017 X5 & 2020 X5
The coding is as follows Left original value right modified value
U_EFF_CL Left: wert_02__aus = 00 Right: wert_08__13,0V = 82 C_CLC_ENA Left: F025_disable = 00 Right: F025_enable = 01 LAMP_MAP_PARA_SATZ_01 Left: BV_F025_wert_99 = 00 00 00 00 Right: BV_F025_wert_02__Cornerlight_ueber_NSW = 07 0E 12 64 LAMP_MAP_PARA_SATZ_02 Left: BV_F025_wert_99 = 00 00 00 00 Right: BV_F025_wert_02__Cornerlight_ueber_NSW = 08 01 12 64 Please note this is for an EU ROW spec car NA spec BMW's may differ
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
05-18-2018, 08:37 AM | #16 | |
Rep 35
05-23-2018, 05:48 AM | #17 | ||
Rep 451
What I would suggest is, assuming you know how to VO code, is add 524 to your Salapa list update your FA and VO code your FRM module. You will get a whole list of errors but at least you will see if corner lighting via the fogs works AND your high beams work. If this works then using the Tokenmaster's tool to compare ncd files reverse the changes via FDL coding the changes that VO coding did for the hardware you don't have ie the turning lamp inside the headlight etc. Please remember to save a copy of your FRM ncd file BEFORE you VO code and directly after you have done it. Good luck
06-09-2018, 12:34 PM | #18 |
Rep 35
Thanks for the suggestion Bambazonke. I tried to VO code and that went fine. It threw a lot of AHL errors but that was expected. I tried to then see if Corner Lighting was working and it wasn't. I am not sure if that was because of the other errors or not. I did run the compare tool and the complete output is below.
The only value that was different from what you suggested was: U_EFF_CL Left: wert_02__aus = 00 Right: wert_04__100% = 32 What I am going to do when I have some more time is try to just change the U_EFF_CL value to the above in addition to the other changes that were recommended but I am not sure if this will work. If you have any further suggestions please let me know. Code:
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN Left: aktiv (Active) = 01 Right: nicht aktiv (NOT ACTIVE) = 00 BLINKZYKLEN_ANZAHL_TIPP Left: UNKNOWN = 05 Right: dreimal = 02 NSW_AUS_BEI_FL Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01 WL_FUNKTION_NSW Left: hard_on = 02 Right: nicht_aktiv (not active) = 00 U_EFF_AL Left: Halogen__13,0V = 82 Right: Halogen__13,1V = 83 U_EFF_FL Left: wert_04__13,4V = 86 Right: wert_02__13,0V = 82 U_EFF_FRA_H Left: wert_02__13,7V = 89 Right: wert_03__13,0V = 82 U_EFF_TFL Left: wert_01__12,2V = 7A Right: wert_03__6,7V = 43 U_EFF_CL Left: wert_02__aus = 00 Right: wert_04__100% = 32 LUT_FLC_FORWARDLIGHTING_Y Left: F001_ohne_AFS = 9C 9C B0 Right: F001_mit_AFS = 9C 9C 9C LUT_FLC_FORWARDLIGHTING_Y Left: F010_ohne_AFS = 9C 9C B0 Right: F001_mit_AFS = 9C 9C 9C LUT_FLC_FORWARDLIGHTING_Y Left: F025_ohne_AFS = 9C 9C B0 Right: F001_mit_AFS = 9C 9C 9C C_BLC_ENA Left: F001_disable = 00 Right: F001_enable = 01 C_BLC_ENA Left: F010_disable = 00 Right: F001_enable = 01 C_BLC_ENA Left: F025_disable = 00 Right: F001_enable = 01 C_AFS_ENA Left: F001_disable = 00 Right: F001_enable = 01 C_AFS_ENA Left: F010_disable = 00 Right: F001_enable = 01 C_AFS_ENA Left: F025_disable = 00 Right: F001_enable = 01 C_CLC_ENA Left: F001_disable = 00 Right: F001_enable = 01 |
06-24-2018, 03:51 AM | #19 |
Rep 451
From your observations I am of the opinion your FRM module does not support corner lighting mine worked straight away even with all the errors after I VO coded it with SA524
Tags |
coding, corner lighting, f25 |
