      12-29-2021, 01:05 PM   #1
cs600
CarPlay coding: Software not detecting NBT2
Folks, I have a 2017 F25. I was trying to enable CarPlay feature.
The software was able to detect my vehicle, but didn’t read from NBT.
Attaching the logs below:
Execution log:
External interface address: 192.168.7.47
Searching for BMW vehicles on the current network
Found vehicle [169.254.72.93]: VIN:5UXWX9C59H0Txxx
Connection to vehicle: [5UXWX9C59H0Txxx][169.254.72.93]
Connecting to remote cloud service....
Connected to remote cloud service.
Process complete: Failed to read from NBT2
Process complete: Server connection closed
Any suggestions what could I do here? The above steps worked a few months back, but my vehicle was at dealerships for a recall, and they also changed the obd port as it was hanging. Would really appreciate some help.
      12-30-2021, 12:15 AM   #2
BlueOnBlue
Drives: 2020 G20 330i
2020 M340i  [0.00]
engine running or off?
i had trouble with mine and had to attempt it a few times, finally it worked after failing
i believe it worked for me 100% when the engine was running
      12-30-2021, 01:08 PM   #3
cs600
I tried both. With engine OFF, the software doesnt the vehicle. With engine ON the software was able to detect the vehicle.
From the error "", looks like process failed while reading the codes from vehicle. Did you face same issue aswell? Let me retry it a few more times now. Will post my update in sometime.
      12-30-2021, 06:20 PM   #4
BlueOnBlue
2020 M340i  [0.00]
no i had the update failed at part 1,
it sounds like yours is failing even before that
but the place i purchased from the fellow was very helpful, i just emailed him and he responded very quickly
      12-31-2021, 08:38 PM   #5
cs600
Thanks for your help. It worked for me finally in one attempt. Here is what i did:
Ran the software on the laptop(vehicle not connected yet)
Input the code
Validation
Connect the vehicle to laptop via enet cable
Find vehicle(had to click a couple of times on the find vehicle button to find it)
Then identify button a couple of times to identify the code and connect to server.(Had to click this a couple of times aswell)
Then start.
Logs:
Execution log:
Installer version: 1.0.13.1
Feature code: 0LHKB-7R9EL
Vehicle VIN: 5UXWX9C59H0Txxx
NBT2 found at 169.254.199.99
NBT2 VIN: 5UXWX9C59H0Txxx
NBT2 CPS: 0T10174
NBT2 Serial#: 0003268252
NBT2 software version: NBTevo_Y21432J
NBT2 software date: 21-11
NBT2 RAM: 4GB
NBT2 has OEM FSCs
HMI_BRAND is BMW
Ready to start.
Working on it...
Running phase 1 of 3
Phase 1 complete
Running phase 2 of 3
Navigation FSC saved to desktop as FSC_0T10174_012100FE.fsc
Phase 2 complete
Running phase 3 of 3
Phase 3 complete
Final step - re-coding NBT2...
Process complete: Success
      01-03-2022, 04:30 PM   #6
BlueOnBlue
2020 M340i  [0.00]
nice... after i did it i have to wait maybe 30-45 minutes with the car off for everything to 'update' so it had all the features enabled when i turned the car back on
otherwise it will seem like its half broken
did you install the wifi antenna yet as well?
      03-09-2022, 07:19 AM   #7
will1604
Drives: 230i xDrive
cs600. Which software are you using to enable CarPlay? Sounds like you are DIY. I'd rather do that if I can rather than one of the services that offer to do it remotely.
Tags
carplay, f25
