      03-02-2021, 12:39 PM   #1
WoodinX3
Drives: 2013 BMW X3
F25 oil pan bolt torque specs
Hi all,
I'm in the middle of the timing and oil pump drive chain job, and need to know the oil pan torque specs. There are 3 different kinds of bolts, and 3 studs with nuts.
When I'm done with the oil pan, would also love to know the torque specs for the following: (N20 4cyl engine)
Subframe to chassis bolts
Differential to oil pan
Axle carrier to oil pan (passenger side)
I'll post some nice pics and outline some of the challenges I faced in this job soon!
      03-02-2021, 01:40 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
See pics....I can't seem to find info re: subframe.
      03-02-2021, 02:14 PM   #3
WoodinX3
Drives: 2013 BMW X3
Thank you for that - the subframe is actually called the axle support and those appear to be the correct values.
Do you have the oil pan fastener tightening torques? These should be something like 8-10 N-m + 90 or 180deg.
I should clarify I have a 2013 X3 with the 4 cylinder N20 engine!
Thank you in advance!
      03-02-2021, 02:28 PM   #4
WoodinX3
Drives: 2013 BMW X3
Awesome!
Thank you so much for posting those torque values! That is really appreciated!
      03-02-2021, 02:29 PM   #5
Wgosma
Originally Posted by WoodinX3 View Post
Awesome!
I'm going to lookup the specs for N20 motor....just a moment, see pic.
      03-02-2021, 04:22 PM   #6
WoodinX3
Drives: 2013 BMW X3
Thank you so much for that! That covers the oil pan to block as well as the 3X oil pan to bell housing - awesome!
Wgosma806.00
      03-03-2021, 04:14 PM   #7
evilchargerfan
evilchargerfan's Avatar
Drives: 2012 F25 (N55), 2014 I01 (REX)
newtis.info is your friend
you're gonna be using it, alot
      03-03-2021, 07:53 PM   #8
WoodinX3
Drives: 2013 BMW X3
Thought it was shut down by BMW, or are there new developments?
      03-03-2021, 08:41 PM   #9
Wgosma
Site is still up, running under the radar...I got registered the day it was shutdown, I'm told there are times when they open to register via email address but no idea how it's controlled. maybe best you can do is periodically check the site.
      03-04-2021, 03:33 PM   #10
evilchargerfan
I have to sign in/log in
but it seems to work, for now
