04-29-2024, 10:03 PM | #1 |
Rep 2
DRL Headlight problem (adaptive + non adaptive mix)
Hello,
I had to replace the left HL on my 2016 35i X3 due a little accident. The right HL is adaptive but the left one isn't (new one). Angel eyes (DRL) are not working on the left one, they only work on the right (adaptive). Obviously I got the AHL error code on the dash. I want to enable DRL and do not care about the adaptive function (it would be nice if I can clear the code tho). I have both modules adaptive and non adaptive. The other day I disconnected the left headlight and switched modules. After that I turned the headlights on and BOTH DRL were working for a few minutes. After playing with the lights knob left DRL stopped working again. A friend of mine tried programming on tool32 and another program and had no luck. I just downloaded ISTA +, however, I am waiting for the ENET cable to arrive. Any insight in how I might make the angels eyes work and eliminate the adaptive error code? Is it possible through ISTA? Thanks in advance. *This will be my first time coding/programming or whatever comes. I am sorry in advance for my lack of knowledge lol* |
Yesterday, 08:22 PM | #2 |
Rep 2
UPDATE
I ended up downloading ESYS and this is where I am so far:
1. Deleted $524 on VO 2. Coded FRM 3. No more AHL error code 4. Left HL DRL is now working BUT Right HL DRL is not 5. High beams not working , Low beams are working tho 6. Launched ISTA to check codes: Adaptive not taught right headlight 7. Tried running the procedure to taught adaptive on right headlight but no luck Just a reminder: - Left Headlight is Bi Xenon Non Adaptive. I did the coding to that module (with its proper non adaptive module) - Right Headlight is Xenon Adaptive (with its proped Adaptive module) I do have another Adaptive Module, which I swapped after steps mentioned above. Indeed, no DRL on both headlights. I will try launching ISTA again with both adaptive modules and see what happens. Anyway, I am going to try tomorrow again. I am not sure if only FRM was needed to be coded or I missed something. Any help is appreciated, thank you. Last edited by Zpieler; Yesterday at 08:31 PM.. |
