03-13-2023, 12:53 PM | #1 |
Rep 3
To CIC or Not to CIC - That is the Question!!
Hi All,
I recently bought an android system to put into my Oct 2013 BMW X3 F25 and was told it is CIC. When the auto electricians went to fit it, they said it was defo NBT. There is loads of info out there on how to identify which system you have, but bizarrely, it all fitted well, but the OEM had no signal. I called BMW who confirmed I had a CIC Mid Variant? 16 pins with 8 pin socket? Does anyone have any idea whether it is NBT or CIC and what I can do with the android system which is CIC? Is there a fix, adapter, wire, anything? The LVDS all connected apparently, just the long press of the menu button turned up 'No signal'. |
03-18-2023, 06:20 PM | #2 | |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
03-20-2023, 10:22 AM | #3 |
Rep 2,527
I had a non-Nav 2013. When I ordered my box, mistakenly provided with a CIC model which uses the LVDS connectors with less pins than the new one. That did not work. Had to mail it back for the NBT version with the newer connectors.
The problem on the X3 apparently has an interim version with NBT connectors but CIC user interface. Typical BMW! Also sadly found out that my factory headunit is locked to the small screen. Unable to upgrade to the wider versions. |
03-21-2023, 12:15 PM | #4 |
Rep 6
My March 2013 F25 has CIC. I believe a lot was changed in April. I think the head unit was upgraded to NBT as well. I know the PWG was upgraded to electronic (EWG) at that time.
