      12-14-2019, 01:34 PM   #1
cohenfive
Drives: 2011 e92 m3 space grey dct
Something's Wrong with My X3 Drivetrain...Ideas?
I have a 2012 X3 3.5 M sport with 98k miles....Until today it has been pretty flawless. The car exhibited some sort of problem that I can't yet figure out, would love to hear your thoughts.
I drive the car up to the Sierra frequently this time of year. It is normally a pleasure to drive...until today's return trip down the hill. The car started acting very sluggishly, hard to put a finger on it. No fault messages at any time. On climbs, even minor ones, when I had the cruise set (81mph) it could not hold speed..so I turned it off. I had real trouble holding speed on anything other than a descent. It felt like the car when 'holding back' when I tried to accelerate. It would have to downshift a couple of gears to hold speed or to get back to speed, something I have not experienced before. In trying to describe it, 'holding back' on acceleration is the best I can come up with...almost like the turbo is not working or barely. Looks like worse mpg on the trip than normal, which I guess would be expected as the engine was working much harder than normal.
Any thoughts before I bring it in would be much appreciated.
2015 M235i, MW/Bl, all packages
2012 x3 m sport, carbon black, prem, tech, conv, etc
evil the following 29'er, specialized carbon stumpjumper s works fsr, trek madone 5.2
nikon d500, d810, d750, 14-24, 24-70, 80-400vr, 500vr
      12-14-2019, 01:43 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
Look at basic engine stuff first-
Proper combustion requires
- air and fuel delivery
- proper spark
So look at age/condition:
-proper fuel delivery pressure (car has 2 pumps..hi/low pressure)
- carbon buildup can occur on intake valves in your direct injected engine- often shows issues at / around 100K mile mark.
-spark plugs....age.
If you have a scan tool, look for any fault codes.
      12-16-2019, 07:18 AM   #3
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
vanos solenoids
      12-16-2019, 08:03 AM   #4
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Vanos issues or one hell of a boost leak
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      12-16-2019, 08:50 AM   #5
Bufalo
Drives: 2009 328i
2017 BMW X3 35i  [0.00]
2009 BMW 328i  [0.00]
It's possible the plastic charge pipe from the intercooler to the throttle body may have ruptured.
najnad171.00
      12-16-2019, 11:36 AM   #6
najnad
najnad's Avatar
This...check this first
      12-16-2019, 02:07 PM   #7
epiphone3
Drives: 2013 BMW X3 35i
It's also possible you were getting the start of limp modes related to higher than normal coolant temperatures if the water pump is starting to fail.
If so, you'd have avoided any warning lamps likely because you are travelling at highway speed and going down hills and lifting and coasting so the temperature didn't go into the yellow warning zone.
I've seen this before. The suggestions above are also worth looking at and fairly easy to investigate.
