      11-14-2019, 08:07 PM   #1
Charlottehanlon
MrLKJ
Drives: BMW X3
Panorama Roof Creaking
Purchased '12 X3 F25 with 85k on it about a month ago in primo condition. Now that the cold weather is here I am hearing rather disturbing creaking noise coming from the sunroof. I am just waiting for the entire unit to crash down on top of me. Is this normal? Is there anything I can do to quiet the sound?
      11-14-2019, 08:29 PM   #2
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Fairly normal, yes. The fix amounts to strategically placing foam in spots to prevent rubbing.
      11-15-2019, 12:07 AM   #3
Opie55
Drives: '15 650i Convertible
Forget foam. You need two small peel and stick rubber pads - the ones a little smaller than an M&M. You put one on each side on the end of a little lever arm. I'll post a pic tomorrow where.
najnad171.00
      11-15-2019, 09:03 AM   #4
dat1guy
Drives: X3 xDrive35i 2016
I'm sure rubber works but I prefer the felt ones in case you place some in areas where some sliding can happen. You can get them in any hardware store for 2$, usually used as door stopper for cabinets. The noise disappears completely.
      11-15-2019, 09:27 AM   #5
Opie55
There is no "some areas". It is two specific spots. One on each side. And felt may compress or rub off.
      11-15-2019, 09:47 AM   #6
Opie55
Here is the picture
Open your sunroof shade, but not the sunroof. Grab that rubber piece just forward of the center bar that divides your sunroof in half and pull it down - you can see in the bottom of the pic I have it pulled down. See the little adhesive rubber thing on top of that little shelf the arrow is pointing to? Just grab that plastic center bar and pull it down - the little shelf will lower with it. Use a small rag or paper towel with alcohol to clean any grease off the little shelf. Stick on rubber thing. Repeat on other side. Don't buy the real thick rubber stops. These are 1/8th inch or so. What this does is slightly lower that center bar across its whole length. That is what creaks.
      11-15-2019, 09:56 AM   #7
Opie55
And to be a bit clearer, you are only pulling down on the front of the center plastic divider bar. It sort of pivots downward. You can pull it down probably a full inch. Just grab it a couple inches inward of the little shelf thing. Finally, before you do anything you can test if this is your problem. Open your sunroof shade and drive your car until it creaks. Take your right hand and hook your fingers over the front of the plastic diver bar near the center of the car - like above the center console - and just pull down a little. Does the creaking stop?
      11-15-2019, 10:54 AM   #8
oVeRdOsE.
oVeRdOsE.'s Avatar
2709
Drives: F25 E91 Audi Avnt E90 Cayenne
https://x3.xbimmers.com/forums/showp...6&postcount=74
      11-15-2019, 11:57 AM   #9
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
very common on F25, there is a thread with simple solution.
      11-18-2019, 04:59 PM   #10
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
I thought I had this issue so I put felt pads on where the arrows point and my creaking got noticeably worse. I took the felt pads off and tested until I realized the only way the creaking stopped was with the windows a little bit down. I went around and pushed in on all of the trim pieces with a result of no change in the creaking...
Any ideas?
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      11-19-2019, 08:58 AM   #11
Opie55
Any ideas?
Not exactly sure what you are saying - are you saying you no longer think it is the sunroof, and a creak is coming form somewhere else or are saying you still think it is the sunroof, but somehow lowering the side windows helps? For a creak to get worse by putting pads where I show in my picture, but get better by lowering the side windows is totally weird. Those two things seem unrelated. But to eliminate the sunroof I would open the shade and drive until it creaks. First try pulling down on the front of the center plastic divider w/o touching the glass. Second, press up on the glass. If neither of those two things makes any difference, it's probably not the sunroof.
      11-19-2019, 09:01 AM   #12
TheCoolX3
Any ideas?
I no longer believe it is the sunroof. I put the pads where directed and the creak got noticeably worse. I tried pushing up on the glass and pulling on the divider bar and there was no noticeable change in the creaking. I could only get the creaking to have a noticeable decline with the windows down. Odd...
      12-14-2019, 07:44 AM   #13
BMW JA
Drives: 13 X3, 73 454 Vette,
I cut the felt pads down to about a eight of a inch thick and then added lithium grease to the surface. Works!
