02-12-2024, 03:40 PM | #1 |
Rep 7
N55 Turbocharger oil inlet/outlet pipes
Has anyone changed out their Turbocharger oil inlet/outlet pipes on their N55's and if so, how big of a project is it? I have quite a bit of oil leaking out of the turbo area and I'm thinking its one of these pipes. The valve cover and filter housing are bone dry. Thank you!
02-14-2024, 07:52 AM | #3 |
Rep 7
02-14-2024, 10:29 AM | #4 |
Rep 286
Drives: E46 M3 & LCI X3 35i M Sport
Any reason why you want to change? Usually you're just good with doing the charge pipe.
If I were to do it I would do it from the bottom. |
02-14-2024, 02:21 PM | #5 |
Rep 7
02-14-2024, 05:51 PM | #6 |
Rep 42
I did it from the bottom for the drain tube, but as far as the oil feed/inlet one I'm not sure. I would search some photos of the N55 out of the car like BMW stock-photos and see if you can locate the inlet tube then see how it looks from being in the car.
I think MWAT might have misunderstood? The chargepipe is irrelevant to your question |
mwat128.00 |
02-15-2024, 07:05 AM | #7 | |
Rep 286
Again though I'd do it from the underside. Put it up on ramps and remove the cover. Shouldn't be too crazy. |
02-15-2024, 04:23 PM | #8 |
Rep 7
