      07-25-2014, 02:38 PM   #1
bowler_1
Drives: 2011 E70 X5 4.0D M Sport
Removing F25 X3 Nearside Headlight Unit
Hi, can anyone help me
I have a 2013 F25 X3 2.0D M Sport and the inner main beam/dip beam light holder within the nearside housing is loose resulting in a misaligned light unit. I would like to take the unit out, it is not an Xenon unit, and see what is wrong.
Does anyone have experience of removing and refitting this unit and if so what is involved. Any help would be appreciated.
      07-25-2014, 04:04 PM   #2
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
There is a screw on top of the headlight that adjusts the main beam. I can take a picture of it later tonight. My driver side light went up one day higher than the passenger side and I started noticing people adjusting their mirrors. The plastic screw on top adjusted it down, and it still levels off correctly every time now during startup.
      07-25-2014, 05:35 PM   #3
///Mposter
Macgyver
///Mposter's Avatar
This levels the main light.
      07-26-2014, 03:37 AM   #4
bowler_1
Hi Mposter,
Thanks for your quick reply. I am aware of how to make the adjustments but my nearside horizontal adjustment does not do anything as the internal light unit seems to be detached and loose. That is why I am asking if anyone has knowledge of removing the light unit.
I have unscrewed the hex bolts securing the unit but I have a horrible feeling that the front panel needs to be removed to remove the whole light unit - hope I am wrong .
      07-26-2014, 10:05 AM   #5
Northandy
Drives: BMW X3 3.0d M Sport
Surely the car is under BMW warranty at that age, take it in and let them sort it.
      07-26-2014, 11:08 AM   #6
///Mposter
Macgyver
///Mposter's Avatar
Originally Posted by bowler_1
Hi Mposter,
Ah yes, usually the headlight comes out after the front bumper comes off. As the other person said, I hope you can still take it in under warranty, whether it is the aftermarket warranty or not. Best of luck!
      07-26-2014, 04:15 PM   #7
bowler_1
As the car is only about 18 months old I have decided to book it in for BMW to have their say.
Will keep posted on outcome.
      07-28-2014, 03:35 PM   #8
Pitiful Old Man
Drives: 2011 X3 35i
Welcome to the world of tight packaging. Not exactly F1 level but not your father's car either.
      07-30-2014, 02:33 PM   #9
bowler_1
Well, took my X3 into the supplying dealer today. They are replacing the headlight unit together with all four centre wheel and front bonnet (Hood to you guys in the USA) decals which are starting to corrode around the edges without any questions asked.
A pleasing result on the headlight as I was half expecting to have to make a stand due to the time since we purchased the car in February this year.
Has anyone else had this decal corrosion issue on an 18 month old F25 X3 ?
UPDATE !!!
All decals and the headlight unit replaced and headlamp beams adjusted, what a difference. No queries whatever.
Have replaced the OEM headlights again with the HID kits that I had originally fitted as took them out as BMW dealers won't touch anything that is different to OEM fitments. Now have terrific dip/main beam headlights that actually point in the right direction ;-).
Last edited by bowler_1; 08-25-2014 at 10:06 AM.. Reason: Update to original post.
      07-30-2014, 03:58 PM   #10
aaccon
Drives: 2023 G21 330i M Sport
Hi
Had all 4 wheel roundels replaced on my F25 at app 14 months. This is common and I also had them replaced on my previous E90 at the 2 year mark.
Cheers..
