      10-27-2023, 08:58 AM   #1
Lasbmwx3
Lasbmwx3's Avatar
Drives: BMW X3
Oil Recommendation
On my last oil change on my 2017 BMW X3 with the 2.0 ltr I used Castrol Edge 5w-30 European formula A3/B4. Now it appears that BMW recommends this oil any longer. Is it safe to use the Castrol Edge for my next oil change or would someone recommend another brand of oil. Thank you.
      10-27-2023, 02:15 PM   #2
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [0.00]
Liqui-Moly 5W30 (BMW LL-01 spec) all the way.
Part #: 2249
BLACK 2017 BMW x3 xDrive28i [N20] xLine Package, Comfort Access, Build Date: 03/03/2017. *[THE POWER OF 33]*
      10-27-2023, 02:56 PM   #3
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
...I used Castrol Edge 5w-30 European formula A3/B4. Now it appears that BMW recommends this oil any longer. Is it safe to use the Castrol Edge for my next oil change or would someone recommend another brand of oil. Thank you.
If the viscosity is correct for your car...and nothing happened during the last oil change...I doubt it will destroy your engine if you used it again.
When you go into the owners manual embedded into iDrive and you search for "OIL"...is the viscosity you previously used correct? The images below were from my 2013 650ix GC (check what your BMW says to verify you're using the correct oil viscosity):
When you say BMW no longer recommends this oil...what do you mean? Or where did you hear/read/see this info?
BMW usually gets courted by various oil/gas suppliers...and will take money from the highest bidder. The last brand that I can remember was Shell. I don't know if they are still the recommended oil/gas supplier or not. But if that's what you're referring to...then no. The Castrol Euro 52-30 is still "safe". They just didn't pay BMW for the recommendation.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      10-31-2023, 12:31 PM   #4
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
BMW LL04…. ACEA C3… 5W30 or 40
      11-01-2023, 09:33 PM   #5
Snoman002
What is this? Where am I? How did I get here?
Snoman002's Avatar
Drives: pre-LCI 14 X3 M
I am trying Pennzoil Platinum Euro specifically for the low NAOCK.
      11-12-2023, 05:30 PM   #6
FranzX3M
Drives: '13 X3M
I have been using castrol edge forever. As long as it's A3/B3 it's fine. 240k kms and going strong. Never burned a drop of oil oil.
      11-25-2023, 05:33 PM   #7
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Not sure I would spend the extra dollars on imported oil when LL-01 and LL-04 oils are available in the US. Specifically, Pennzoil that is owned by Shell (which seems to be BMW's favorite at the present). Another supplier is Quaker State (also a Shell company) that offers two of LL oils recommended by BMW.
The mystique of European brands also flourishes in the Porsche forum, where that company specifies Mobil 1 oil, but many members tout Motul and Liqui Moly.
Granted Europe is the only place to find BMW's recommended LL-12e for its newer diesels, but it seems ridiculous to pay almost a $100 per oil change, when the old standard, LL-04, sells at Walmart for less than half that price.
      12-03-2023, 05:15 PM   #8
ClutchFC
Drives: X3 35i
Motul Xcess. Used in my previous 335 with N54, and have continued so in the X3 N55. Works great, love the stuff. I also use LiquiMoly Engine Flush each oil change.
      03-29-2024, 07:35 AM   #9
Super_X5
Drives: X5
X3 oil
F26 recommended oil
      04-16-2024, 12:14 AM   #10
MaverickIX
Drives: BMW X3 2.8I 3.0 engine
My choice is Liqui Moly Special Tec B FE 5W-30, recommended
      04-16-2024, 06:47 AM   #11
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
I was using this until my local parts plug could not get anymore, so I switched to https://www.liqui-moly.com/en/ca/spe...0314.html#2249
LM2249 Special Tec LL SAE 5W-30
      04-18-2024, 06:43 PM   #12
MaverickIX
I'm ordering in US that oil it's much cheaper than in local parts shop, even with delivery
