      08-14-2014, 12:39 AM   #1
Auto
Sweden
170
Drives: MB CLS 63 AMG
Smile Does X5 E70 19"/20" wheels fit X3 F25?
Are these 19" wheels going to fit a X3 F25?
2x 9x19 ET18 5x120 72,5 mm 255/50R19
2x 9x19 ET37 5x120 74,1 mm 255/50R19
Also does X5 E70 20" fit?
Thank you!
      08-14-2014, 06:35 AM   #2
JensM
Germany
64
Drives: BMW X4 M40D 2019
Auto
The center bore on the F25 rim is 72,5mm - on the E70 it is 74,0
I do not think it is wise to add rings of 1,5mm to make the E70 rims fit
      08-14-2014, 08:36 AM   #3
02420X3
Drives: 2011 X3 35i
An ET of 18 would not be good. From an older post:
Basic wheel specifications for the X3(F25) chassis are:
Bolt Circle = 5 X 120mm
Offset = 45mm (43 to 47mm acceptable)
Hub centering Bore = 72.5 mm (hub ring dia. = 72.47mm)
Bolts = M14X1.25 Spherical seat, 17 mm heads (Note the X3(E83) uses M14X1.5 bolts)
Minimum bolt engagement = 9.5 turns
      08-15-2014, 11:44 PM   #4
iX3
Drives: X3, 28i
Here is a nice site for comparing wheel/tire sizes.
http://www.rimsntires.com/specspro.jsp
