      05-07-2018, 08:47 PM   #1
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Rattle noise near torque converter
This noise sounds like a bad serpentine belt idler pulley bearing. I was under the car while it was ideling and it is coming from in between the engine and transmission. Car runs/shifts perfect. Any ideas ?
2011 28i N52 with ZF 8 speed
      05-08-2018, 08:41 AM   #2
Barbera335
Drives: F25
You may be missing these sound insulation caps, P/N 24 14 7 603 258 and P/N 24 14 7 567 139. They plug holes in the bell housing between the engine and the transmission. This is the TSB pertaining to it. Unfortunately I cannot find the full version. http://www.tsbsearch.com/BMW/SI+B24+03+11
      05-08-2018, 03:22 PM   #3
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Thank you
      05-18-2018, 06:43 PM   #4
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Took a peek under the car and they aren't installed. Ordered them and they should be here in a week or so. Will report back
      08-22-2019, 08:08 PM   #5
Troy27
Drives: Bmw f30
Bringing up an old thread....I have the same noise. Went under my car and it's definitely coming from the front of the transmission where the torque converter is. My caps were missing so I put my hand up to cover the hole and it seemed to quiet the noise. Did you ever install the caps you ordered? And did it help?
      06-15-2020, 09:25 AM   #6
n55ke
Drives: 2011 f25 3.5i
BIG_KID did the caps help?
      06-20-2020, 08:20 AM   #7
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Sorry, haven't been on in a while
YES, the caps helped....
      06-20-2020, 08:48 AM   #8
e30lover318i
Drives: E30,E34T,E46,F48
Hopefully this info helps I had a sound that seems to be similar, a sound almost like a failing power steering pump. I put some info on page 2
https://x3.xbimmers.com/forums/showthread.php?t=1730424
