06-12-2011, 08:23 PM | #2 |
Rep 12,276
I got this warning in the X5 once, after spending several hours cleaning it. I had opened and closed the rear hatch several times and the interior lights were on for a long time. Just take it for a decent length drive and it will charge back up. If it happens frequently or without any apparent cause, you might want to contact the service department.
I think it is bad luck to be superstitious |
06-12-2011, 08:35 PM | #4 |
Rep 161
We were gone for 12 days and never received that message.
BTW Flash3,did you order the paint (from whom) and have you tried touching it up yet? |
06-12-2011, 08:42 PM | #5 | |
Rep 654
Yes I did and from the same link in the thread I started. - I haven't received it yet though... |
06-12-2011, 08:52 PM | #6 |
Rep 654
Is there a reason why I received this message and why it happens/happened? Is it something to schedule an appointment at the service dept for?
Is there a device I can purchase from either BMW or somewhere else that will allow the battery to keep its charge, even when it's not used for a few days at a time? I will be traveling again for work in a few weeks, and the car will remain unused for 2 weeks and want to take care of the battery to avoid issues. |
06-12-2011, 09:01 PM | #7 |
Rep 2,294
Some BMWs (and other makes) will discharge if left sitting for extended periods of time (but one week is pretty short). If you are away for weeks, a very wise investment would be a battery trickle charger. Cost is in the $100 range but solves that entire problem, and is easy to connect. My '08 535xi was bad for that, and that's when I bought the trickle charger and never had that problem again.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
06-12-2011, 09:03 PM | #8 | |
Rep 654
What's the best place to purchase a trickle charger and is does BMWNA sell them specifically for the X3? Or can I get one from Advanced Auto Parts and places like this? How does it work? /noob |
06-12-2011, 09:25 PM | #10 |
Rep 1,560
flash3, remember the thread you started before you left for your trip? It is here: http://x3.xbimmers.com/forums/showth...rickle+charger
Gives you all the info you need |
06-12-2011, 09:29 PM | #11 | |
Rep 654
06-12-2011, 10:44 PM | #12 |
Rep 2,294
You can get it from BMW or maybe a auto parts store. A trickle charger is not specific to any car. Works on them all. Attach it to the battery post and ground under the hood (manual shows where, IIRC), and plug it in. That's it. I left mine on for 9 weeks once, no problems.
06-12-2011, 11:42 PM | #13 |
Rep 1,041
See the previous thread you started. There are several good "smart" chargers listed there.
With the standby current load on a new X3, the battery might last as long as 21 days or even more depending on the temperature and the specific set of options on your car. BUT, and it's a big but, it all depends on the state of the battery charge when you park it. The Brake Energy Recovery System allows the battery to sometimes drop down to a 50 to 60 % charge instead of the typical 90 -95% charge that "older" cars (who's alternators run all the time unlike the X3's) are kept at. If you park the car when the battery is "low" you could be almost fully discharged in 10 days. If you travel often, a good "smart" charger is an excellent investment. I use the Battery Tenders and have always had good results with them. Remember: On a X3, all of the 12V. accessory outlets are switched off after a short time delay, so can't be used to charge the battery. You must connect directly to the charging posts under the hood. The CTEC chargers are also excellent and are sometimes re-branded and sold by BMW, Mercedes and even Ferrari as their own parts. see: http://www.ctek.com/EN-GB/corporate/news.aspx?id=52 |
06-13-2011, 06:59 AM | #14 |
Rep 12,276
Ah, sorry - I didn't make the connection of you being away for a couple of weeks. Lotus7 has provided the tech info on the charging system, so if this is something that you're likely to do once in awhile then a smart charger would be a good investment.
06-13-2011, 07:25 AM | #15 |
Rep 654
Lotus - you are the man! Thanks for the details, and plenty of it.
So I am assuming this was normal and bound to happen, given the situation? Anything to worry about or talk to the dealer about? LEDZEP - thanks for the info, as well! |
06-13-2011, 07:31 AM | #16 |
Rep 5,097
Flash, I use this one on both my bmw's, especially my z which gets stored for roughly 5 months every year. Use to get similar issues like yours until I started using the trickle charger.
http://cgi.ebay.ca/BMW-ADVANCED-BATT...item3cb8e300f8 As Lotus noted however, the chargers that plug into the lighter socket won't work....you need to get the type that connects directly to the ground/red connectors located in the engine bay. Dave
06-13-2011, 08:08 AM | #17 | |
Rep 654
What did you do to remedy the issue when it happened? Do I need to do anything specific or take it to the dealer? |
06-13-2011, 08:16 AM | #18 |
Rep 5,097
Hi Flash, no I didn't swing by the dealer. I assumed that was the issue the first couple of times it happened (also happened on an '09 Lexus I owned a couple of years ago). Once I started using the charger on the cars (not driven for say 10 days or more), the issue never popped up again.
Given the number of "things" that continue to operate on most cars these days, even when you think everything has been powered off / shutdown, and given the number of days you'll be leaving your x3 unattended, it's pretty likely you're in the clear, insofar as any electrical or some software issue. Dave EDIT: Sorry, missed a line in your previous post. No, didn't do anything specific to remedy the situation at the time, simply drove around for a 1/2 hour or thereabouts to get it charged up again.
06-13-2011, 08:27 AM | #19 | |
Rep 1,041
Another charger choice that I like is the Black & Decker BCS10B. It's one of the few Black & Decker chargers that works well. I have one and use it for quick charges. It works fine on the X3 and will charge the battery fully in less than 5 hours. I like the fact that it has a digital display that tells you what's happening (i.e. the charging voltage and if the connections are correct, as well as a analog meter that displays the total charge in the battery. The meter is accurate on the X3 "SM" battery only after it's been connected and charging for at least 1/2 hour. see:http://www.target.com/gp/detail.html/184-7892956-1667451?asin=B0024GJ4IM&AFID=[DESTINATION]_df&LNM=|B0024GJ4IM&CPNG=electronics&ref=tgt_adv_[XSVALUE] There are several other B & D chargers, but the BCS10B is the only one I'd recommend for a X3. The downside (compared to the CTEK) is that it has a variable speed fan that makes some noise when the charger is working at full power. |
06-13-2011, 08:37 AM | #20 |
Rep 654
Lotus - you are the man, once again!
It's in the garage right now but later this afternoon, I am going to take it on a drive and then this weekend, I will take it to the dealer for a check up. |
06-13-2011, 09:10 AM | #21 |
Rep 1,041
If your dealer has one in stock, I'll bet he tries to sell you the BMW charger (a re-branded Battery Tender).
