09-12-2011, 05:40 PM | #1 |
Rep 59
Driver window--very light popping noise
Hi all,
I've noticed a really light popping/clicking noise from the top left portion of the driver's window (guess that'd make it the aft portion of the window, high up by the pillar). I suppose it could also be coming from near the top of the door panel, where it intersects with the glass. I'm 99% certain the dealer will tell me CND but hoping maybe others have had something similar with a solution I can site. It doesn't sound like anything loose (not a loud rattle) just that it's not fitting really well and there's some pressure on the frame/window transition area when over undulating road surfaces (even very small imperfections). Hot/Cold, doesn't seem to be different. Anybody hear the same thing? I'll add that my 09 535XI had a louder issue of the same thing that I never tried to fix... Car is going in tomorrow for a persistent (okay, it's only happened twice) LOW COOLANT issue, a left brake lamp intermittent caution, and the leaking water on the passenger floorboard. Giddyup. |
09-13-2011, 08:28 AM | #2 | |
Rep 1,781
It's the door lock. Mine does it, too. Pull the door handle to the point of resistance and you'll hear the same noise. Going to get it fixed soon. |
