      11-15-2022, 09:58 AM   #1
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [0.00]
carbon cleaning?
have any of you done carbon cleaning on your n20 engine's?
My x3 is at 95,000 miles (153K KM) and I am thinking of getting walnut blasting done and cleaning the intake valves of carbon...
has anyone done it yet?
or should I wait a little longer?
if you did get this done, how much did it cost you?
I know BMW's aren't that bad as Audi/VW
      11-15-2022, 07:50 PM   #2
Opie55
Drives: '15 650i Convertible
Personally, I would not do it absent symptoms, which typically includes a rough idle at low rpms. But even if I was thinking of doing it, it is not too hard a job to pull the intake manifold back a couple inches to see the valves. They will always be black, but unless they are really gunky, leave them alone.
      11-16-2022, 08:28 AM   #3
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Originally Posted by Opie55 View Post
Personally, I would not do it absent symptoms, which typically includes a rough idle at low rpms. But even if I was thinking of doing it, it is not too hard a job to pull the intake manifold back a couple inches to see the valves. They will always be black, but unless they are really gunky, leave the alone.
Yes, that is true.
I only experience rough idle during cold start, but it goes away when the RPM needle settles.
It feels like the engine is misfiring but it is not, I check the car's misfire count and it's always 0.
I feel an engine vibration when the car's RPM settles, but it goes away within 10 seconds after the RPM settles. It's been like this ever since I got this 2017 x3 in January 2019 at 50,000KM (31,000 miles).
I will keep an eye on things, if I don't see any misfires/rough idle during cold start, I will not do CC... I will wait it out.
Thank you for your feedback
      11-18-2022, 09:42 PM   #4
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Completely useless. Don't waste your money unless you have a pcv valve issue.. which you don't.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      12-16-2022, 01:29 PM   #5
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Nope, no issues at all, no CEL, no codes, nothing. My 2017 x3 (N20) drives smooth. No issues at all (thanking the car gods).
It's just that I was told to get carbon cleaning done on ALL direct-injection engine vehicles.
I will hold off until I see issues.
I'm going to get the brakes serviced and brake fluid flush and refilled instead.
