      05-04-2012, 07:22 AM   #1
dudley07726
Drives: 2012 X3
2013 Mercedes Benz ...  [0.00]
2012 X3  [0.00]
Radio / Nav presets
I noticed that when I touch the preset buttons I can see what station is preset for that button. There are other times when I touch the same button, it doesn't show me the radio station but a Nav preset address that my dealer created. I do not know what I had touched previously to make one or the other show.
How can I create presets for Radio and Nav addresses whereby the same button is good for both.
      05-04-2012, 07:58 AM   #2
Yeltzer
Yeltzer's Avatar
12
Drives: F25 xDrive 20d M Sport
I don't think you can. You get 8 presets to allocate across radio, nav, telephone. That's 8 in total not 8 per function.
Will happily stand corrected if I'm wrong though
F25 xDrive 20d M Sport in Alpine White, Pro Nav, Auto 'Box, 19" Wheels, Visibility Pack, Heated Seats, Reverse Cam w/ Top View, Sun Protection Glass, DAB radio
      05-04-2012, 08:19 AM   #3
swallowtail
Australia
Drives: 2018 M2 Competition DCT
You can't. One function per button, EXCEPT that each profile can have different ones. All thoroughly explained in the manual.
Current drive: 2018 M2 Competition DCT, Sunset Orange
Previous: BMW X3 xDrive 30d
      05-05-2012, 08:40 AM   #4
dudley07726
Drives: 2012 X3
2012 X3  [0.00]
What do you mean by each profile? I still do not understand how preset button #1 had a radio station and my home address at the same time. As I said earlier, I do not know what I might have done before hand that when I pressed #1, the radio station played. Another time, I pressed #1 again, my home address showed.
      05-05-2012, 09:35 AM   #5
Nahoa
But can you get the radio station to show up again? I expect that you won't be able to. Sounds to me like you may have re-programmed the button to your home address, replacing the radio station that had been stored there before. These buttons can be programmed to almost any setting in iDrive by holding for a long press when the setting is displayed.
Are you certain you were using the same key both times and that the same profile was active? As noted above, if you changed profiles (by using the other key, for example) the settings of those buttons will be whatever was set under that profile. Check the profile section in the manual to see how these are created and switched.
There are no "banks" for these buttons to the best of my knowledge. One item per button.
      05-05-2012, 10:38 AM   #6
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
If you "hover" your finger over the 1 -8 buttons it shows what function/station it is a assigned to.
      05-05-2012, 11:09 AM   #7
Botwin
Botwin's Avatar
Drives: 2015 WRX Limited
You are probably alternating which key you use. Each key is a different profile, and therefore has different radio presets, etc. To keep from driving yourself crazy, always use the same key, and keep the other in a drawer somewhere.
      05-05-2012, 12:29 PM   #8
dudley07726
Drives: 2012 X3
2012 X3  [0.00]
Ah! Okay. In the morning, it's my wife's key as she is driving me to the bus stop. Other times, it' s my key which the dealer probably had made the first preset my home.
Thanks
      05-06-2012, 07:59 PM   #9
Fryguy29
Drives: 2011 BMW X3 35i
I had no idea the presets changed based on which key was used. That is so freaking cool!
      05-06-2012, 08:24 PM   #10
Harplayr
Drives: 2011 BMW X3 28i, F25
That way she won't know you've programmed the Playboy station as a XM preset.
