02-28-2012, 08:50 AM | #1 |
Rep 69
Headlamp Courtesy Delay Feature
I've read the manual and can't figure out how this works. I have the lights set in Auto position. When I turn off the car and lock it the lights go out. I thought they are suppose to stay on for the set amount of time so you can have your pathway lighting. This is how they work in other cars.
02-28-2012, 08:57 AM | #2 |
Rep 90
Not sure if this is the same in the US but here is how it is supposed to work for UK models.
After switching off the ignition, you pull the headlight flasher (the stalk on the steering column) to flash the lights before getting out of the car. This should activate the low beam headlights for a duration set in the Settings | Lights | Home Lights section on the menus (via iDrive) Hope that helps |
02-28-2012, 09:57 AM | #5 |
Rep 983
Briefly pressing the Diamond symbol (Panic Mode, Courtesy Headlights) on your remote may also turn on the Courtesy Headlights, depending on the options that you have.
02-28-2012, 10:05 AM | #6 |
Rep 69
Thanks for the responses. Briefly pressing the panic button works for sure. Have to check and see about pulling the flasher before exiting. This is our first BMW and there are certainly quirks with it. On every other car I've had including my Audi the lights just stay on after locking for the amount of time selected.
03-06-2012, 04:10 PM | #7 |
Rep 63
Flasher before exit does not seem to work on mine even after setting the delay time etc.
Manual seems to suggest it should work if the lights are switched off - this seems rather obtuse - surely it should work if the lights are (have been) switched on or in Auto when the car is switched off. |
03-07-2012, 09:55 AM | #8 |
Rep 24
Just a suggestion - try doing it at night. If the car senses broad daylight, I don't think a 100 lb pull on the stalk would do anything. If the car senses night (pretty well dark) I think just a slight tug will get you the desired result. sam
03-07-2012, 09:17 PM | #9 | |
Rep 1,876
03-08-2012, 01:31 AM | #10 |
Rep 90
I picked my car up yesterday and tried this. After turning off the ignition and radio etc (two presses of the start/stop button - not sure if this is relevant), I pulled the stalk towards me briefly to flash the lights.
The lights stayed on whilst I got out of the car and stayed on for the duration I set up in the vehicle settings via iDrive. The headlight switch setting was in the automatic position throughout Do you have Xenon headlights? I don't know if that is relevant but maybe it only works for Xenons |
03-11-2015, 03:56 PM | #11 |
Rep 5
I am new to this forum, and new to BMW (assuming you don't count a 325i 30 years ago). Two weeks ago, I picked up a 2015 X3 28i (USA). This forum has helped me immensely, and I truly can't thank everyone enough for all the valuable information they have provided. Two things continued to confound me, though. First, it took me forever to figure out the audio/Bluetooth/USB system, but I think I've now got a pretty good handle on that. Then there was the "Headlight Courtesy Delay Feature." The manual made no sense to me, and nothing I tried seem to work.
I just got off the phone with one of the "geniuses" at my dealership. Here is the exact protocol he recommended (I keep headlights in auto mode): (1) hit "Start/Stop Engine Button TWICE; (2) Open Driver's Door; then (3) Pull high beam flasher before exiting vehicle. Upon reflection, I had been pulling the flasher before opening the driver's door. I have NOT tried this yet. I intend to do so this evening. But in the meantime, wanted to both provide you with this information and also again thank everyone for providing such a helpful resource. |
