10-28-2015, 10:49 PM | #1 |
Rep 40
Drives: 2011 x-3 28i x-dr, 2012 335i
x3 xdrive tranfer case?
grabbed a great deal on a low mileage 2011...my old mercedes ml430 needed a transfer case oil change every couple years..whassup with this beast? TIA, dan
10-29-2015, 02:50 AM | #2 |
Rep 510
Interesting question. The first generation E83 X3 was notorious for problems with its transfer case. One of the great claims about the current generation F25 X3 over the E83 is that the xDrive transfer case is greatly improved. Over the 4 years and 80,000km (50,000 miles) since we got our X3 and joined this forum I haven't seen too much mentioned about the transfer case (the steering rack is of course another story).
However having said that, just in the last two regular services I've had the "sealed-for-life" transfer case flushed twice. After the second time I asked my service guy and was told it had become a common practice for the F25. The two flushes didn't cost me anything because they were done under warranty (I have a 5 year warranty on our X3). I asked what happens after the warranty on the car runs out and he really didn't have an answer. If I keep my F25 beyond its warranty I'll certainly be formally asking BMW for an explanation and continuing coverage for this transfer case flushing. What to look for is a slight hesitation on gear changes when starting off and with some small turn on the steering wheel. When I first experienced this I thought it might have been the dreaded steering rack problems. However in both cases after the transfer case was flushed the problem disappeared. Tony |
10-29-2015, 07:52 AM | #3 |
Rep 73
Has anyone done a transfer case fluid change? I did it in my last X3 (e83) and it was the easiest thing ever. I'll probably take a look under the car to see if it has easy access to the drain/fill bolts. I thought I'd heard it wasnt as easy as the last generation. Typical.
11-01-2015, 07:52 AM | #4 |
Rep 40
thanks replies, guys. seems to me, a lot of the 'magic' of bmw's x-drive HAS to happen in the transfer case...
the ML-430 was pretty easy; drain, fill it till you spill it, b-flat ATF...never any major symptoms, but boy that stuff sure got black after a year or 2... I'd bet a replacement unit is very pricey... regards, dan in texas |
11-03-2015, 11:43 PM | #5 |
Rep 40
i found a u tube video for a gen 1 x-3...the 'secret sauce' fluid looked a lot like synthetic 75w gear oil, 700 mL...
have seen others quote $150 plus plus for a dealer ?? wonder if that's the same for gen 2 transfer cases? and i KNOW BMW is not in the oil bidness...but, they just don't want me to do anything myself ?? drove my gen 2 x3 in some rain on a long'ish road trip; i'd give it a 'pretty good' in borderline hydroplaning road conditions at 80 mph, FWIW.. regards, dan |
11-10-2015, 01:37 PM | #6 | |
Rep 1,772
11-11-2015, 01:31 AM | #7 | |
Rep 510
Tony |
