      01-15-2012, 02:01 PM   #1
123x3
Drives: x3 2005
hand brake problem!!!
Hi Guys
X3 2006 2,0 d
The ratchet on my hand brake is worn on the sixth to the eighth tooth, and the brake isn't tight enough to hold the car on the fifth click up. If the level is pulled up past the eight tooth the brake is fine and will hold the car on any slope. How do i go about tighten the cable so the lever will only travel to the fifth click and hold the car ? Somebody menstioned two nuts under the level but i've not got any i think its self adjusting?
      01-19-2012, 07:09 AM   #2
x3oiler
Drives: X3 3.0 Diesel
On other cars I have owned the handbrake is self adjusting. Drive the car in reverse and use the handbrake to stop it - i drive slow and yank the handbrake a few times as you slow down. This should adjust it. Not sure on the X3 though.
X3 3.0d 2006 update, DVN-E83 GPS with reversing camera, Alpine SPS410 in doors, Earthquake SWS-8X (4ohm) under seat driven by Alpine PXE-650 and Pioneer GM-D9500F amp, Superchip ECU remap.
      01-23-2012, 02:12 PM   #3
ADClapp
Drives: BMW X3 2004 2.0 Diesel
Hand Brake
I had the same sort of issue and it required the replacement of the handbrake lever and cables, to be fair it cast about £175 all in.
