02-24-2016, 01:54 PM | #1 |
Rep 10
F25 2.0d SE Tyre life.
Hi, can anyone tell me the sort of rear tyre mileage they are getting from their F25? I'm currently in a dispute with the local main dealer after a brand new set of rears were destroyed (through to the canvas!) on the inside edge after 12000 miles of relaxed driving. I say there has been a fault with the wheel alignment since the car was bought used a year earlier but the service manager tells me this is perfectly normal for an F25 X3 and wants me to pay £90 for an alignment check. Tyres are Pirelli Cinturato 225/60/R17 RFT's. Your replies may give me some ammunition for the next confrontation with the dealer. Thanks.
02-24-2016, 02:09 PM | #2 | |
Air Vice Marshall
256
Rep 1,639
I am currently on 20k miles and it looks like they will last another 5,000 miles or so, but this is after tracking. Unfortunately most BMW dealers will not pay up after you have gone past 6 months of purchase from them. I said it is obvious that that the tracking was out when I purchased it, but needed to be sure after after a further 5,000 miles. I stood my ground and they did it at trade rates in the end. If the £90 is for full alignment and adjust, in my view that is a good deal. I found mine needed adjusting and necessary before fitting winter wheels and tyres. |
02-24-2016, 02:18 PM | #3 |
Rep 10
Thanks Peter R
I should have mentioned that after 3 months of purchasing the car the same thing had happened. At the time, I complained and asked them to rectify the problem. As a result they fitted new tyres and they told me that a 4 wheel alignment check had been done at their cost. 12000 miles and a year later and the tyres were destroyed again which, to me, says that the alignment check wasn't carried out in the first place. |
02-24-2016, 02:49 PM | #4 |
Rep 5,984
This has been discussed ad infinitum on the BMW forums over the last few years since run flat were introduced.
BMWs have always had quite an aggressive set up, but the inner edge wear was only slightly ahead of the rest of the tyre. Problem with run flats is there is less flex in the side wall and thus it sits on that inner edge more so. You can dial it out a lot with different pressures, and even better change the geo set up. Other option is just put proper tyres on. It took my old man 2 sets of rears in under 6k miles each to make the swap to non run flats, the second set were down to the cords and actually had the sidewall come away from the main tyre on the passenger side. When he swapped to proper tyres he still had 6mm evenly across the whole tyre when he sold it some 10k miles after fitting them. Problem with letting BMW change your geo is they will change it to the standard set up, which in your case simply isn't working. Maybe give someone like wheelsinmotion a call and discuss with them? |
02-24-2016, 02:51 PM | #5 | |
Air Vice Marshall
256
Rep 1,639
That suggests to me that something is seriously amiss. It would be questionable that they did a full alignment check in accordance with the BMW procedure. Did they give you the print out or at least show the results of the alignment check showing the before and after figures? Just saw gIzzE reply. I would suggest you stay with the original dealer. If you go to another one, then you will lose all claim with the first one. Note. My front tyres were wearing on the OUTSIDE and when they did the check they gave me the print out showing the before and after figures and showed and explained how the correction would affect the wear. They were spot on and the result is that I will now get full mileage from these tyres on the 3 litre diesel. Last edited by Peter_R; 02-24-2016 at 03:01 PM.. |
02-24-2016, 02:56 PM | #7 |
Rep 10
Yes, a BMW main dealer.
No, there was nothing recorded on the invoice or a printout of the alignment check. In hindsight I should have asked for it, but at the time I was delighted to get free tyres! |
02-24-2016, 03:00 PM | #8 |
Rep 5,984
What year is the car?
Maybe they are using old geo set up figures? have a look at this thread... http://www.wheels-inmotion.co.uk/for...showtopic=4707 |
02-24-2016, 03:02 PM | #9 | |
Air Vice Marshall
256
Rep 1,639
Go back and push them hard. Speak to the Principal and advise the if you are not satisfied, you will take it up with BMW. Last edited by Peter_R; 02-24-2016 at 03:04 PM.. Reason: additions |
02-24-2016, 03:15 PM | #10 | |
Rep 10
Checked out the tyre forum and it made for interesting reading, however I did manage to clock up 30000 miles from the rears on my previous 3 series M sport plus which runs 35 section RFT's on 18in rims so it definitely seems like the geometry setup. |
02-24-2016, 03:19 PM | #11 | |
Rep 10
I've already complained to BMW uk customer service and they've basically just referred me back to the main dealer, so what a waste of time that was! But hey, I'm determined to get some form of resolution from the dealer! |
02-24-2016, 03:48 PM | #12 |
Rep 2,524
Our other X3 has run over 50,000kms on the factory all season run flats and they still have decent tread on them. Pretty sure you have an alignment issue.
02-24-2016, 05:55 PM | #14 |
Rep 15
25,000 on the same model with the same tyres as yours, and looking good for another 10,000miles
X3 Xdrive20d M Sport Auto,M Sport plus package, Media Professional Plus package, electric folding towbar, reverse camera, convenience access, HUD, Space Grey
02-24-2016, 06:17 PM | #15 |
Rep 5,984
Do check your pressures, on mine it says 29psi F and 32psi rear.
If you are using those pressures you will get that inside edge wear, the side wall is so hard that you just end up putting all the weight on it. I would try 34F and 36R for a more even wear. |
02-25-2016, 08:46 AM | #17 |
Nuclear Chief of the Watch
120
Rep 637
We have done 34k miles on winter / summer sets - both sets still have 6-7mm on them.. So sounds like a car issue.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
02-25-2016, 10:55 AM | #18 |
Rep 363
This is what i'm using on my tyres. 34F and 36R. i used the same pressures on my E60 530d and it always wore the tyres down evenly
2014 X3 30d Lci M Sport in Black Sapphire. Pro Nav, Black Leather,Adaptive Xenons, Extended Storage, Lighting Package, 19" Staggered (622M) summer wheels, 17" style 304 winter alloys
