      09-17-2011, 05:41 AM   #1
clivem2
Drives: X3 M40i
Playing CD-Rs
I have a load of CD-Rs I want to use in my car. The CD drive will sometimes read them and display all the tracks. If I take the CD-R out and put it back it then won't work, the display says "no disc" and other CD-Rs struggle to work, success maybe 1 in 10 attempts.
CDs are fine so I expect it's the reflectivity of the Verbatim discs I use - normally they are pretty good. Has anyone had success with another brand or similar issues?
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D
      09-17-2011, 05:55 AM   #2
Bustofa
Drives: F25 X3 XDrive20D SE
I know you say these are CD-Rs but is that definite? I only ask as CD-RWs can often be problematical - more so than write once discs.
      09-17-2011, 06:43 AM   #3
clivem2
Drives: X3 M40i
Definitely they are CD-R, I've just tried a Sony CD-R, this reads fine but it's a CD image (wav), not MP3 which the Verbatim disk are. The issue could be a problem reading MP3s, I'll play around with some burning options.
      09-17-2011, 07:35 AM   #4
clivem2
Drives: X3 M40i
I'm doing much better with UDF format instead of ISO + Joliet. The tagging doesn't show up as well but the disk reads fine.
Edit: I'm probably the only person here without USB audio......in case this helps someone...strangely ISO + Joliet format now works so I have better tagging (Artist and Album show up). I suspect the drive needed more physical actuations from new to work properly, or maybe it won't work on the move. Either way it seems like the problem was/is a physical one.
      09-17-2011, 02:56 PM   #5
clivem2
Drives: X3 M40i
It was working fine a couple of hours ago but now fails on ISO + Joliet format but is ok on UDF so it's have trouble reading some formats from time to time. As it's not a hard fault it must be a mechanical problem with the CD drive. I just know I'm going to have fun at the dealer.....
      09-17-2011, 03:05 PM   #6
Bustofa
Good luck!
      09-17-2011, 05:58 PM   #7
MattUK
Captain Unsensible
MattUK's Avatar
Drives: 2016 M240i Coupe - Estoril
2016 BMW M240i  [0.00]
I find it better to write all disks at a slower burn rate, no more than 2x even if the disc supports more, then it has better success in reading them.
