06-17-2014, 06:16 PM | #1 |
Rep 137
2015 X3 front license plate holder
I just purchased a new 2015 X3 Xline, and want to mount a license plate on the front of the vehicle without having to drill holes. Has anyone found any screwless license plate holders that fit the 2015?
06-17-2014, 08:26 PM | #2 |
Rep 147
"Skene Design" works well. Does require a couple of small holes under the bumper (but not drilling into the face of the bumper). There also are other creative lower cost options (zip ties, etc) and several quick release systems that attach to the front tow hook.
2020 X1 sDrive28i l Xline l Luxury l Harman Kardon l Wireless l Parking Assist l Sliding/ Reclining Rear Seat
SOLD - 2013 X3 35i l BSM l MSport l DHP l Premium l Sound l Tech l CW/CWII l Apps l 35% Tint SOLD - 2010 E92 335 X-drive l BSM l MSport l Steptronic l Premium l CW l Logic 7 l Confort l Nav l KW-V1s l 35% Tint |
06-18-2014, 06:51 AM | #3 |
Rep 11,843
Drives: MY24 G01 AW Msport
i have one for sale, oh wait are u in the US? lol
06-18-2014, 08:13 AM | #4 |
Pygocentrus Piraya
927
Rep 1,008
Drives: 2021 BMW X3MC
They actually listened this time and didn't drill out my front bumper. I am going to try and see if I can find a way to center it under the front bumper. Are you allowed to trim the plate down an inch or 2?
Otherwise, this in white. http://www.usmillworks.com/bmw_front..._tow_hook.html
kozzi
2021 BMW X3MC Donington Grey Metallic / Sakhir Orange & Black Extended Merino Leather / Aluminum Carbon Structure |
06-18-2014, 12:35 PM | #5 |
Rep 59
Screwless number plates
Hi BMW-X,
I have used double sided tape, 15/20mm wide, for a number of years on a previous X5, X1 and current 2013 X3. Just make sure that you very lightly sand the back of the plate (ours here in the UK are oblong front and rear ) and also VERY LIGHTLY with very, very fine sand paper or equivalent paste the corresponding areas in three places on the body. Make sure these are 5/10mm in from the corresponding area of the plate so that they are not visible. I have always used this method and provided you are careful and take your time it is almost impossible to see the sanded areas when the plates are removed. Needless to say all surfaces must be completely free from dust and moisture when being applied. I have always had all our cars jet washed and hand washed at local washes without ever having any plates come loose. Also have a Ford C-Max and that is the same . Hope this helps. |
06-18-2014, 10:36 PM | #7 |
Rep 37
I fully understand the reason why one wouldn't want to drill holes into a perfect virgin bumper. What I don't understand though is why the tow hook mounted license plate holder is any better -- aesthetically it looks awful and very unbalanced, screwing up the look of the front end.
You'll need that license plate mounted the entire time you own the vehicle (unless of course you move to a state that doesn't require such). When you go to sell/trade the vehicle, having holes or not having holes won't matter either way. It just seems odd to me to endure this off balanced look for the duration of ownership. My bracket hasn't been drilled in yet, but when I get my license plates next month it won't pain me to see it drilled into the center of my bumper providing a clean, balanced look.
2015 F25 xDrive28i M Sport: ZDA | ZDB | ZLP | ZPP | ZTP | DHP | Heated Seats | HK Sound
Past BMWs: 2011 E70 xDrive50i 2006 E90 330xi |
06-19-2014, 12:15 AM | #8 |
SPEED RACER
375
Rep 740
http://www.usmillworks.com/ have an amazing product!
06-19-2014, 04:55 AM | #9 |
Rep 137
Well I live in Germany right now and will need to put a European plate on the front of the vehicle. I don't want to drill holes because the state I'll be going back to does not require front plates. I do think the tow hook plate holders look awkward, but would not mind it since I would not be using it once back in the states. My only concern with that type of license plate holder, is wether or not it will block the sensors?
06-19-2014, 05:54 AM | #10 |
Rep 147
Google "Skene Design". Can center and adjust height of plate. European design also available.
06-19-2014, 07:53 AM | #11 | |
Pygocentrus Piraya
927
Rep 1,008
I plan on driving without a front plate. Yes, I know I will eventually get pulled over and that's when the tow hook holder comes into play. Sorry officer I forgot to put it back on after a wash etc. Is it ideal? No. If it becomes such a PITA that I have to permanently attach it to the front, I'll try painting the bracket, tap it below the center clips and 3M it the top so it hopefully never comes loose. Screws into the plastic front bumper just don't work over time. Maybe I just had bad luck the first time around. Who knows. Would sure love to hear other ideas.
kozzi
06-19-2014, 08:17 AM | #12 | |
Rep 11,843
i bought lighten standard one but in black..the one with many holes.
even though i requested not to drill holes on front bumper, they still manage to do it . so im stuck with license plate holder Quote:
06-19-2014, 08:19 AM | #13 | |
Rep 11,843
this design will not effect the parking sensor, you can check the website and it tells you how to mount.
Won't interfere with front parking sensors (PDC) X5 Owners - because the plate must be fully offset for PDC, we recommend the Lightened kit. Available in standard and lightened kits. See gallery below for more pictures. scroll to the bottom where the pic of X3 F25 with msport bumper http://www.usmillworks.com/bmw_front..._tow_hook.html Quote:
06-19-2014, 09:24 AM | #14 |
Rep 37
I couldn't agree more! I wish I was able to do as you suggest, carry the front plate around with you until pulled over. In the city of Denver unfortunately they'll get you when you're parked. They have a zero-tolerance for it. No plate, $75 ticket greets you as you return to your vehicle.
06-19-2014, 09:31 AM | #15 | |
Pygocentrus Piraya
927
Rep 1,008
I also like the Skene Design but it would need a plate holder. Can't see how the flimsy metal of a plate wouldn't get all messed up and damage the front bumper at highway speeds.
kozzi
06-19-2014, 09:43 AM | #16 | |
Pygocentrus Piraya
927
Rep 1,008
kozzi
06-20-2014, 08:13 AM | #17 |
Rep 11,843
plate holder is not flimsy lol
i still have mines wrapped up, we can meet up and u can check it out for urself before u order it i have the quick release one for when u need to wash the X3 |
07-04-2014, 11:43 AM | #18 | |
Rep 4
07-13-2014, 10:57 PM | #19 |
Pygocentrus Piraya
927
Rep 1,008
I ended up using zip ties to add and remove the plate holder. I can put up some pics if you want.
kozzi
08-05-2014, 08:11 AM | #21 |
Rep 4
I bought the towhook plate holder from cravenspeed for my 2015 M nose X3 and it works great. Does not interfere with the front parking sensors and the people at cravenspeed (cravenspeed.com) were very responsive and super friendly. (+ it is cheaper then the US millworks solution who never replied to my last 3 emails).
Can put up some pictures if you want. |
