      06-17-2023, 12:37 PM   #1
lbalan79
Drives: BMW X3 2014
INSTA+ ICOM Next Connection Issue
Hi all,
I have issues connecting through the ICOM interface to my F25. I was able to connect using ISTA+ directly using an ENET cable connection but because I am looking to update the ILEVEL I got an ICOM Next.
Using ITool Radar I can see the connection and also when I start Easy Connect I can get the interface locked and reserved. However whenever I start ISTA+ and try to connect all connections drop and time out. I am not able to see the connections after trying to identify the vehicle and I get connection time out no matter what tool I use (including web admin interface). If I restart the process by disconnecting ICOM from car and rebooting it I can see it again until I try to connecting in ISTA+. Any help is appreciated.
Some specs: ICOM Next: ICOM A1 Firmware: 03.22.21 (Clone)
ISTA+: 4.32.15
ITool Radar: 1.1.1 ( works fine)
Easy Connect: 7.3.0 (works fine) I use remote IP and BASE as per this guide: https://www.bimmerownersclub.com/for...w-icom-next-a/
Disabled all protection under Windows and everything works fine using ENET direct cable.
Please let me know what I am missing.
