06-09-2023, 07:17 PM | #2 |
Rep 104
There are a couple of fuse boxes. 1 in the front on the passengers side. There should be a card in the rear box. It's located on the right side under the trim. The card is folded and in a slot at the bottom of the box. Hope this helps.
06-10-2023, 05:23 AM | #3 |
Rep 350
Looking at the wiring diagrams for 2010-2014 models, there are up to 5 different power points.
Fuse 54 - 12V connection front cigarette lighter & 12V connection 3 Fuse 65 - 12V connection 4 Fuse 143 - 12V connection 5 Fuse 144 - 12V connection 2 Other than the front cig lighter on 54, I can only guess the locations of the others. I think that 54 is the cup holder and back of the console positions. Fuse 65 is the inside console position. These are both in the front fuse block. In the rear block, it specifies fuses 143 & 144, but to the best of my knowledge there is only 1 port in the cargo area. I have no idea which of the two it is.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
