05-26-2023, 10:47 AM | #1 |
Rep 13
Center Grille Part number / Match for pre LCI X3
Does anyone know if this center grille will fit the pre LCI version of X3? I am trying to retrofit ACC and got few parts already.
https://www.turnermotorsport.com/p-1...uine-bmw-part/ Thank you |
06-07-2023, 11:17 AM | #2 |
Rep 539
Check this link, they have some info about fitment:
https://www.ecstuning.com/b-genuine-...n/51117347971/ |
06-07-2023, 12:22 PM | #3 |
Rep 7,487
If you need to know or have the BMW 11 digit part number…you can run that number through one of the online part database sites like www.realoem.com or www.bimmercat.com where both sites have a BMW part number search feature that will show you what other BMW models use the same part number…or if there are older or newer part nbrs that are retroactively exchangeable…and if there is a production run date that would apply based on build date (if you use your VIN to pull up the diagram/part number index).
Example using part number from info provided in original post: https://www.realoem.com/bmw/enUS/par...971&series=F25 Then if you click on the link for the model you have….it will take you to the diagram and part number index that provides additional info like production run and option code info etc.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-07-2023 at 12:32 PM.. |
