      08-20-2012, 09:56 PM   #1
flash3
Drives: X3 28i
Tailgate Rattle
I have noticed an increase in rattles and noises as I drive around.
Sounds like it's coming from the rear. Like I have a bag of pipes and each bump i go over. a metal clunking noise comes from the rear
Anyone got anything similar, or is this just normal for such a car?
      08-20-2012, 10:30 PM   #2
purpleplus2
Drives: X3 35i
Tailgate rattle
Check the black rubber adjustable bumpers on the trunk. One on each side. Try adjusting them, helped fix mine.
      08-20-2012, 10:31 PM   #3
flash3
Drives: X3 28i
Adjust them how? With what?
      08-20-2012, 10:55 PM   #4
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Unscrew them a little. Tailgate should equally rest on them.
      08-21-2012, 08:41 PM   #5
purpleplus2
Drives: X3 35i
You can turn them by hand, no tools needed. Keep adjusting till rattle stops.
      08-22-2012, 12:34 AM   #6
RSchneider
Austria
Drives: 2011 X3 xDrive30d
My dealer did adjustments three times so far, and it keeps coming back. And actually I'm not sure it has to do with these spacers. I think that sound is a result of some lateral movement of the hatch when the car body flexes, and that can't be mended by adjusting the spacers.
      08-22-2012, 01:02 AM   #7
swat4167
Drives: F25 28i
I found the similar sound come from the storage compartment, when you open it, can see the big plastic storage in which 2 top sides hit the alumimum bars! Try try!
      08-22-2012, 04:56 AM   #8
clivem2
Drives: X3 M40i
I find only one of the plastic bumpers rotates. The other seems to be fixed or is it stuck?
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D
      08-22-2012, 12:01 PM   #9
Jurisprudent
Jurisprudent's Avatar
21
Drives: '15 335i M-Sport
Clive I thought the same, but a little more force and the one that seemed stuck came loose. Turning it counterclockwise, I believe.
I'm still battling this issue (or one very similar), but adjusting them has helped a little. Still get some noise, but not as much. Will keep trying, as dealer just wants to ride along/doesn't hear anything (naturally). I'm going to have better luck doing it myself, I'm sure.
      08-22-2012, 02:46 PM   #10
Mingstar88
Drives: BMW X3 35i
sounds like an issue im having, im not 100%, dealer cant fix the issue, said something about plastic is expanding crap. i drove their loaner x3, no noise whatsoever.
THOSE who have fixed it, please post pictures to share with the community please!
      08-22-2012, 03:53 PM   #11
flash3
Drives: X3 28i
      08-26-2012, 08:53 PM   #12
Jurisprudent
21
Still working on it. Once I'm confident I have actually fixed I'll try to post pictures. The metallic rattle is getting much better, but I still get a creak every now and then on flex
      08-27-2012, 10:58 AM   #13
pantong
Drives: 2013 X3
I just picked up my new X3 last week and I'm having the same problem. Please post some pictures on how to fix it. Thank you!!!!
      08-27-2012, 12:26 PM   #14
plob
Drives: 650i GC
Hi all
I had a similar issue with my car. It turned out to be the extensible cover in the boot (trunk).
Take a look at the following thread
http://x3.xbimmers.com/forums/showthread.php?t=687509
This may not be the same problem you are having but I hope it helps
Cheers
P
      02-05-2013, 07:30 AM   #15
fr33styl3
Drives: 2018 X3 M40i & 2020 X5 40i
Sorry to bring back an old thread but I've had the dealer tried to fix this 3 times now and each time it comes back within a matter of weeks. So tired of this issue. Just wondering if anyone has had a fix completed and not have the issue come back since?
On another note, does the tailgate make a really loud noise when you open it electronically from the inside? I feel like it's the sound of someone slamming the door shut really loudly. Not sure if this is normal or not.
      02-05-2013, 08:11 AM   #16
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
BMW Toronto (downtown) fixed the tailgate issue for us. They just reseated it in the manner as others described. Hasn't come back.
The tailgate does make a noise. Sounds more like a tupperware popping than a slammed door though
      02-05-2013, 01:16 PM   #17
BenDiem
BenDiem's Avatar
Drives: '19 M240i xDrive
I had rattling emanating fom the rear cargo area as well. I opened the rear hatch and adjusted the rear seats; I essentially pulled the seats into their track...
My issue was a loose rear seatback, not fully retracted in the locked/upright position.
Let's hope that is your fix as well.
Like the OP and others, I think an SUV will eventually lend itself to some creaks/rattles, due to the rear cargo cover and moveable rear seats. I believe it's the nature of the car...
GL/Cheers,
BB
      02-05-2013, 01:28 PM   #18
Mingstar88
Drives: BMW X3 35i
read this
http://x3.xbimmers.com/forums/showpo...73&postcount=5
      02-05-2013, 01:54 PM   #19
BenDiem
BenDiem's Avatar
^^^ Thanks for sharing!
      02-06-2013, 08:04 PM   #20
Shaw
Shaw's Avatar
Drives: 2016 X5 35d | 2019 X3 30i
YES YES ME ME!!!
I still haven't been able to explain the cause and effect, but based on your description we are having an identical situation...
      02-07-2013, 01:44 AM   #21
plob
Drives: 650i GC
Are you sure it is the tailgate that is rattling? The reason I ask is that some of us on this forum experienced a similar problem which we traced to the cover in the boot (trunk) area. I'm talking about the one that attaches horizontally across the back seats that you pull out with a handle so that it disguises the contents of the boot.
I don't know how to attach a link to the thread (sorry - I couldn't figure it out) but if you search for "Bloody rattling cargo / trunk / boot cover" you will see some more information.
I'm not saying this is the same problem you are having but it is worth checking out as it is easy to fix if it is.
Good luck
Cheers
P
      02-07-2013, 06:00 AM   #22
Mingstar88
Drives: BMW X3 35i
Good luck
Cheers
P
hey plob, not sure if u missed my post earlier in the thread
i added your post from the other thread here http://x3.xbimmers.com/forums/showpo...73&postcount=5
ppl should check out!! it worked for me
