      07-02-2022, 03:52 PM   #1
electricsnails
Drives: 07 E83 X3 | 01 Land Rover D2
07 E83 X3 Overheating question
Hey gang,
I am new to the forum and mostly new to the world of BMW, I have an 07 X3 that I have had for the past 3ish years without incident that has developed an overheating problem that I cant get to the bottom of.
after a bit of driving, temps climb to 235ish and sometimes as high as 250 if I am driving up a steep long windy hill. I feel like the temp gauge would have climbed into the red if I had let it. the issue seems to be the most pronounced when under load, even when moving. At a red light temps drop down a bit.
Here is what I have done so far;
Replaced thermostat
Confirmed that the water pump is working
Bled the system properly
Replaced engine coolant temp sensor
Replaced rad fan (it was found to be not working)
My observations are:
Engine oil and Coolant are the right colours and flavours
No leaks or consumption of coolant
No coolant smell
What is a reasonable next step or tests I could do?
      06-29-2023, 06:02 AM   #2
Teds01
Drives: 2006 X3 2.5 si
Hi,
Any luck sorting this out?
      07-03-2023, 11:13 PM   #3
GT4560
Drives: X3 1st Gen (456)
How about checking to see if your fan is functioning.
Of course you've run the scanner...what fault codes were discovered?
