08-03-2016, 04:27 PM | #1 |
Rep 8
Power Tailgate Issues
I've done searches on this and quite haven't found what I was looking for.
I just recently purchased a 2011 X3 28i x-Drive with almost everything on it (cold weather package, comfort access, nav, etc.). When I test drove it at the dealership (not a BMW dealership), everything was working fine, including the power liftgate. When I took it home, there was an error message in regards to the battery needing charging. Once I drove it around, the error message went away and then it came back. Last night I hooked it up to my conditioner and no issues. However, the power liftgate does not work and has not worked since I brought it home. Is there something I'm missing here? |
08-21-2016, 11:03 PM | #2 |
Rep 227
Make sure you keep the key a good distance away from the vehicle. If not, it will not sleep and drain the battery.
Not sure what to tell you on the liftgate. I'd take the car to a good independent mechanic if you didn't have it inspected before you bought it. |
