      10-09-2016, 06:35 AM   #1
chesterflaps
Drives: BMW X3 Msport X30D
M47 engine with fault 4175 exhaust temp sensor fault
Hi.
I have had a problem for a few days where I lose power at 2,000 revs in any gear. I was told the DPF was blocked and needed regenerating. Sadly it will not regen and there is a fault code 4175 coming up for the exhaust gas temp sensor.
I have had the sensor replaced (one before the DPF) yet the problem persists and it still says the same fault is there on the sensor.
As there is this fault I cannot force regen the DPF.
Does anyone have any ideas what might be at fault here?
