      02-19-2016, 12:38 PM   #1
kkglcivic
Drives: 320d m-sport plus
replacement part fitted now a question about the fault codes
Ok guys, 55 plate x3 3.0 diesel m57n2 the fault code I had was 'P2620 Throttle position , output signal - open circuit'
quick bit of research shows its the throttle body.
so I have replaced the throttle body, question is will I need to get the fault code removed or will the ecu clear it itself when it sees the replacement part
      02-20-2016, 02:00 AM   #2
Mikesmith2939
Drives: 2013 320i xdrive
Best to get the codes cleared.
You can get a handheld BMW specific code reader on Ebay for around £30, this will read and clear codes.
