      11-18-2020, 02:26 PM   #1
335twins
335twins's Avatar
Drives: 2020 x3 M40i, 2019 M2Comp
spark plugs
I replaced my spark plugs about 30k miles ago in my 2012 X3 35i (around 80k miles), I'm at 110k right now . Am i due for another change? or is it every 50k miles?
Thanks
      11-18-2020, 02:59 PM   #2
ItsmeX5
Drives: 2018 X5, 2013 M5, 2007 SL55
Depends what you look at. I usually change mine initially at the 60k mark then again at 100k and have never owned a vehicle much passed that to pass it again. As easy it is to change them in these cars I would do it if I were at you’re mileage
Edit: misread your post. You changed plugs 30k miles ago I would not change them again. Coils if original would be about time
      11-18-2020, 03:45 PM   #3
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
Thanks
Stock engine; every 60k miles / 100,000km unless you have issues with a misfire.
Tuned engine; depends on the tune but 30-40k miles as a starting point.
If the ignition coils are original then consider changing those soon, they will be near the end of their life.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      11-18-2020, 04:50 PM   #4
335twins
335twins's Avatar
so changed the spark plugs 30k miles ago so they should be fine, but the coils i didn't touch. I have a some hiccups at idle and wonder if this is related to spark plugs or coils.. its not bad, but it happens here and there...
      11-18-2020, 06:58 PM   #5
ga9213
Drives: 2018 X3 M40i
I replaced coils at 60k with eldor when I did ngk plugs. I would probably go with coils...your plugs should be fine with only 30k on them.
      11-18-2020, 08:08 PM   #6
335twins
335twins's Avatar
Where did you purchase the coils? was it directly from BMW?
      11-18-2020, 08:39 PM   #7
6MT_Addict
6MT_Addict's Avatar
FCP Euro is hard to beat. I did my coils recently and it took care of idle hiccups with plugs replaced a few thousand km earlier.
      11-18-2020, 08:54 PM   #8
335twins
335twins's Avatar
Thanks, which ones you got? Bosch, Delphi or Genuine BMW <--pricy
      11-19-2020, 09:13 AM   #9
Commerce
Drives: 2019 X3 M40i
Go with Delphi since they're the OEM supplier. BMW used to use Bosch but switched to Delphi after some issues. GN10571 is the Delphi part number.
      11-19-2020, 09:38 AM   #10
383vett
383vett's Avatar
I replaced my plugs with Bosch earlier this year and my 2012 3.5 runs great. 88,000 mi.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      11-19-2020, 09:52 AM   #11
ga9213
No, Eldor are the newest and best designed coils for the N55. Better than Delphi
https://www.ebay.com/itm/6x-BMW-Igni...-/152335261416
12138657273 is the newest version. Go with these. I monitored via torque for any misfire counts on any cylinder after the change and it was zero across the board.
      11-19-2020, 12:43 PM   #12
6MT_Addict
6MT_Addict's Avatar
Delphi, but Eldor is fine too.
Eldor superseded Delphi which superseded Bosch.
      11-19-2020, 01:09 PM   #13
evilchargerfan
evilchargerfan's Avatar
Drives: 2012 F25 (N55), 2014 I01 (REX)
I just purchased delphi's per 6MT_Addict recommendations
