      11-02-2015, 10:16 AM   #1
335twins
335twins's Avatar
Drives: 2020 x3 M40i, 2019 M2Comp
tire recommendation?
I have a 2012 X3 35i and need new tires. I am going with regular tires as i think the Run flats are not needed and are way too expensive for what they provide. I live in an area where its mostly sunny. Any recommendations?
Thanks
      11-02-2015, 11:02 AM   #2
Polo08816
Drives: 2014 335i M Sport
Thanks
I usually look on eBay. Some people are selling brand new Chinese branded Michelin's for about 1/4th of the price off TireRack. I've never had an issue and those have kept a lot more cash in my wallet for gas money.
Tire companies are going to hate us, but you'll be able to outsmart them with one other simple trick. You can buy used tires and re-tread them with something as simple as a box cutter.
      11-02-2015, 11:52 AM   #3
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
when it comes to tires, dont be cheap when you drive 50k vehicle.
Its fine to go with regular tire as suppose with runflats.
you can go with summer tire or all season tire, if you dont have winter season.
      11-02-2015, 02:31 PM   #4
335twins
335twins's Avatar
I had RFT on my 335 and when i switched to cheap non run flats i learned my lesson, good thing was that when i called the tire place they said to come back and they will give me better tires for a bit more money, thank god, cause the new tires are so much better..
      11-02-2015, 02:42 PM   #5
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
i may pull the trigger on the new DWS06 tires, non rft . Just buy the kit in case of flat.
just go on tire rack, go by the selection given. Shop around with local tire shop for better prices.
      11-02-2015, 02:51 PM   #6
335twins
335twins's Avatar
That's what i'm thinking, which kit are you talking about? i have the rubber/glue kit.
      11-02-2015, 02:56 PM   #7
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
it sealant and air pump.. tire rack has it..dont know the name of it.
      11-02-2015, 02:58 PM   #8
335twins
335twins's Avatar
Are these the ones you buying:
Continental ExtremeContact DWS 06
      11-03-2015, 07:39 AM   #9
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
yes
the kit is CONTICOMFORTKIT $79
      11-03-2015, 09:21 AM   #10
335twins
335twins's Avatar
yes
Great, I'll check with discount tire as they are local if they have these or can get these for me. The kit looks really good, way better than buying RFT.
Thanks again.
      11-03-2015, 09:33 AM   #11
335twins
335twins's Avatar
yes
forgot to mention, but i heard if you use this kit, you will need to replace your TPMS sensors otherwise you will get a warning light every time you start the car.
      11-03-2015, 10:37 AM   #12
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
i wasnt aware of that, where did you find that info?
      11-03-2015, 10:58 AM   #13
Tjalle
Drives: X4 35i
People who are not fond of sealant - like tire shops - claim that sealant will destroy the valve in your TPMS. I don`t buy that - but it might be true.
So, if a puncture - sealent - you might have to replace that specific sensor - less than $100. Since punctures are rare it is not much of a threat.
NOTE: there are "pirate" sensors that can be programmed for your vehicle - I have four, for my winterwheels They might not have same life as original. We are talking 3-5 years instead of 5-7 years
The Contis are all you need in the desert.
      11-03-2015, 11:16 AM   #14
335twins
335twins's Avatar
http://www.e90post.com/forums/showth...fortkit&page=2 -- check page 2, it looks like you can clean the TPMS sensor once the tire is off and being repaired.. I don't care really, i can replace the TPMS sensor or try to clean once the tire is off and being fixed..
      11-03-2015, 11:43 AM   #15
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
i just placed my order ..delivry for tomorrow
      11-03-2015, 12:57 PM   #16
335twins
335twins's Avatar
order for tires or the conticomfortkit? I found "Slime Safety Spair" that could work as well and it doesn't mess with the TPMS.
      11-03-2015, 01:14 PM   #17
Tjalle
Drives: X4 35i
Beware of the Wolf!
I don`t trust people claiming slime will - always - destroy your TPMS valves.
Also I don`t - until proved otherwise - believe that Slime Safety Spair, will never destroy your valves.
That said - enjoy your slime, you will probably never need it
      11-03-2015, 01:33 PM   #18
Polo08816
Originally Posted by Tjalle View Post
Beware of the Wolf!
By that logic, if you prefill your tires with slime, you will never have to worry about a flat tire. It will always be sealed.
      11-03-2015, 01:43 PM   #19
335twins
335twins's Avatar
Beware of the Wolf!
I agree, I am trying to decide which one is the best option from the following:
1- conticomfortkit
2- The slime spair
3- BMW one
      11-03-2015, 01:57 PM   #20
Tjalle
Drives: X4 35i
Since you will probably not need it, I would go for EL Cheapo.
I took this discussion as an Omen, and just ordered a similar kit from Amazon UK, at a cost of £24 (no postage within UK), but for me £31.
I need it -for peace of mind - for my winter tires.
It is a bit scarey, since they saved my details fom last purchase about a year ago, and now just needed my details, including personal code, but not card nr nor electronic gizmo.
      11-03-2015, 02:12 PM   #21
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
I order the tires, i have wheel n tire insurance so anything happens tire gets replaced or fixed. tire also come with road hazard protection.
      11-03-2015, 02:17 PM   #22
335twins
335twins's Avatar
Got you, I just don't want to be stuck in the middle of nowhere with a flat tire...
