      10-01-2023, 12:09 AM   #1
Glene
Drives: 335is
2006 X3 - no crank - no click - no start
After getting gas, trying to start the car, but did not hear anything, all lights on dash are good. Car ran fine until then. Jump start, but no change. If the starter is bad, I'd expect to hear the click sound. What could cause this? Any suggestion?
Update: The ground strap near the passenger engine mount deteriorated and causing this problem. if you have no crank issue, run a cable from the negative post to the Vanos bracket, if the engine starts, then the ground strap is causing the problem,
      10-02-2023, 02:17 AM   #2
Ralph11
Drives: BMW X3 e83
Ignition lock, relay, alarmsystem, starter, wiring….. you will need to measure from top to bottom and or use tester to check for failure codes, would start with measurements
      10-20-2023, 04:49 AM   #3
GT4560
Drives: X3 1st Gen (456)
I had a similar situation not totally. Just came off a 1800 mile round trip. X3 sat for a couple of days and wouldn't start...successfully I jumped it, got to my destination. Then again no start. Come to find out the alternator was bad changed it out now no problems with the starting.
