      07-04-2021, 09:09 PM   #1
Marsplay
Drives: BMW X3
Need help please: park light/daytime running lamps malfunction
I'm new to the group and thank you for accepting me as a member.
I have an issue with my F25. Got this warning ⚠️ and says park light/daytime running lamps malfunction on my dashboard. upon checking, the tiny T10 bulb on the front passenger side (my X3 is just the halogen version model) is out. Bought a new one but still won't light up. Inter changing the bulbs still nothing. Where do I check now? Kindly advise please... Thank you in advance.
      07-06-2021, 01:25 AM   #2
Marsplay
Drives: BMW X3
Anyone?
      07-06-2021, 10:08 AM   #3
dtox9
dtox9's Avatar
Drives: '17 X5 F15
This may sound silly - but did you try rotating the bulb 180 degrees and re-inserting it?
Additionally could check inside the socket for bent contacts or corrosion, etc...
      07-06-2021, 05:33 PM   #4
Marsplay
Drives: BMW X3
Yes i did that several times ��
      07-07-2021, 12:53 AM   #5
Bdavi011
Drives: 2013 BMW X3 3.5i
Not sure what else it could be besides a bad connection? Check the fuses? No corrosion or cut wire?
