      07-02-2021, 05:16 PM   #1
sbacchus
Drives: BMW X3
Help with valve cover /injector pipes
All I'm doing my valve cover and noticed that I don't have any flare nuts holding the injector pipes to the rail. All of the diy videos I've seen as well as realoem show nuts there. How is it possible these high pressure pipes are on my car with no nuts? Hoping someone who has done this job on this car can comment on whether they had nuts there.
      07-02-2021, 05:30 PM   #2
WagonR
Drives: 2017 M2
Weird, I definitely had nuts there on my 2013 3.5i. I'd have to guess that you'd need to undo the nut at the end of the fuel rail, anything else holding it on, and take the whole thing out. That's a pain...
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
      07-02-2021, 05:49 PM   #3
WagonR
Drives: 2017 M2
Okay, got curious and looked it up. Seems like the instructions for replacing the fuel rails show a different style than everything else. I'm guessing this is what you'll need to do.
Uninstall
Reinstall
Those torques on the reinstall are:
1) 13Nm
2) 23Nm
3) 30Nm
With both 2 and 3 noting that you should coat the screw connection with transmission oil. I would say I did not do that on my traditionally laid out one...
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
      07-02-2021, 06:07 PM   #4
sbacchus
Drives: BMW X3
This is exactly what I guessed I needed to do and did. Where was that procedure, TIS?
Uninstall
Reinstall
1) 13Nm
2) 23Nm
3) 30Nm
      07-02-2021, 06:08 PM   #5
sbacchus
Drives: BMW X3
decided to just pull the entire rail
WagonR293.00
      07-02-2021, 06:13 PM   #6
WagonR
Drives: 2017 M2
Yeah, it had one that was replacing the rail (with pressure lines) which is what I copied the images from. All of the just pressure line ones were different, with nuts on both sides. Not sure why there'd be a difference, but looks like you got it sorted!
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
