      05-23-2016, 10:36 PM   #1
khaug
Drives: 2018 BMW X3 340i
Two Questions, Please
1) Where is my X3's battery located?
2) Can the car be set so a single pull on an interior door handle opens it? If so, how?
Thanks.
-Karl
      05-24-2016, 01:34 AM   #2
Pinewood
Pinewood's Avatar
Drives: BMW X3 30d M sport LCI
1. The battery is located in the rear under the floor. Remove the flippable cover and you will see two plastic screw in tabs. Undo these to reveal the battery.
2. From settings, disable the auto lock function. Otherwise i am not aware of a method to achieve this. Maybe ask in the coding thread?
      05-24-2016, 10:44 AM   #3
momoboy
Drives: F15 35i 2017
For question 2 it can be coded. With coding, the car will still auto lock and when you stop and shut off the motor the doors will unlock
