      05-14-2016, 07:30 AM   #1
Jordster
Drives: X3 xDrive 28i
Question about tires - worn after 10k miles? Suggested replacement?
I got a screw in one of my tires. I wanted to get it repaired and was told that run flat tires cannot be repaired. Is that true? The puncture is on the bottom of the tire in between the tread.
I was quoted something ridiculous by the local shop to replace a single tire. They also pointed out that my other tires are mostly worn. I only used them for about 16000 km / 10000mi before I put the snows on. I don't drive like an old lady but nor am I doing burn outs. Is this typical of these tires? In previous cars I've never used up a set of stock tires in less than 50k km. What gives here?
Finally, any recommendations for a high performance all season tire (no run flat!!) to replace it with? Or perhaps a summer tire? I have snows for the winter.
Thanks for any ideas / suggestions. This is crazy!!
      05-14-2016, 08:51 AM   #2
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
Run flat tires can be repaired in many cases, provided that the sidewall and shoulder are not damaged and the hole is not too large. How far did you drive on the tire with low or no pressure? Did your local shop remove the tire and check for damage to the sidewall on the inside?
http://www.tirerack.com/tires/tirete...jsp?techid=226
What is the tread depth remaining on your other tires? Generally treads on new tires are about 10/32 inch in depth. I typically replace worn tires with less than 6/32 inch of tread, but some owners will drive tires to much lower tread depths. If you put on a new tire with a significantly greater tread depth than the worn tires, this may put some stress on the driveline.
http://www.tirerack.com/winter/tech/....jsp?techid=18
      05-14-2016, 09:15 AM   #3
Jordster
The shop (it's a tire shop, not BMW) just said they won't fix holes on runflats as its not a good practice. I can't really tell if that's true.
I don't actually know how long the hole was there. I found it when switching back from snow tires. I did get a message about the tires last season but thought it was just an error. X3s in Canada don't have TPMS (can't believe BMW cheaped out on that one, it's not required by law, so they use the ABS sensors to somehow monitor the tires, and when they throw an error you get an error message that points to all 4 tires, not the one with the problem).
The tread is 5mm left on what were the rears and 6-7mm left on what were the fronts. Aside from the odd time I've been very gentle on this car!! I don't get it.
I think I'm going to order a new set of Conti DWS06.. .Seems to be a well reviewed tire that fits the car nicely.
      05-14-2016, 10:13 AM   #4
Pinewood
Pinewood's Avatar
Drives: BMW X3 30d M sport LCI
I had a huge nail in the middle or my rear tyre (275/40/19). BMW, and all the major chains said they would not repair it (health & safety nonsense)
A back street tyre guy repaired it, but when he has the tyre off the wheel, have a real good look around the inner sidewalls for any tears and damage. If there is none, you will be fine.
I did all of the above and it cost me just £15. The tyre has remained on the car for 3 months now with no issue whatsoever.
      05-14-2016, 12:08 PM   #5
Eaglesview
Drives: X3 28d
My Canadian 2015 X3 has TPMS.
The vehicle came with Goodyear run flats. Had a nail towards centre of tread, no sidewall damage, repaired. Was told if tire brand was a Continental or Perelli it woild be non repairable.
      05-14-2016, 12:42 PM   #6
Pinewood
Pinewood's Avatar
My tyres are Pirelli P Zero runflats. Perfectly fine since the repair. Also with TPMS on a late 2014 X3 in the UK
      05-15-2016, 03:14 PM   #7
Jordster
Are you sure? My friend and I both have a 2015 Canadian X3. Maybe it's a provincial thing. We are both in Ontario. No TPMS. His got totalled and replaced with a 2016 - no TPMS on that, either. All 3 vehicles w/ Premium Enhanced.
      05-15-2016, 05:01 PM   #8
MichiganMike
2020 X3 M40i  [0.00]
The linked article below notes reports that some run flat tires do not offer as long a tread wear life as conventional tires.
"Many owners on the AutoGuide Forum Network complained that they were replacing their OEM run-flat tires within 20,000 miles."
http://www.autoguide.com/auto-news/2...-buy-them.html
FWIW, the same article mentions the recommendation by BMW that OEM run flat tires be replaced with run flat tires.
      05-16-2016, 10:12 AM   #9
Jordster
Of course BMW recommends run flats. They chose to offer the car without a spare tire. They have to recommend run flats by law. The dealers will further pedal this BS because run flats, especially LS2s, and a very high margin item.
BMW isn't the only company selling this cost-cutting, profit boosting measure as a feature, but for all intents and purposes a run flat tire will always be inferior to an otherwise identical conventional tire. Unless you drive a lot in the great wilderness there is no reason you need a spare. BMW assist is safer.
      05-16-2016, 11:26 AM   #10
MichiganMike
2020 X3 M40i  [0.00]
FWIW, I believe that manufacturers may also supply cars with conventional tires and a pump sealant kit for repairs instead of a spare.
http://techmax.ca/run_flat_tires.htm
At least in the USA, BMW suggested prices for its approved tires seem high compared to competitors. This is not limited to run flats.
      05-16-2016, 11:59 AM   #11
Pinewood
Pinewood's Avatar
That is a great article, and resounds with me a lot. If a M car can use normal tyres, why not the rest of us.
      05-16-2016, 12:25 PM   #12
Braumin
Drives: 2013 335i xDrive Sedan
Assuming you didn't drive on it flat, there's no reason it can't be repaired. Generally nails don't cause instant deflation and the TPMS or wheel speed sensors will tell you quickly when the tire is low.
If it was driven on flat, then they would have a point due to the heat buildup in the sidewall.
      05-16-2016, 08:44 PM   #13
Greg2010
Greg2010's Avatar
Drives: 2020 X1 sDrive28i
I have 30k miles on my OEM RFT Goodyear Eagle LS2s (with 25-40% tread life still remaining)...and noticed a nail embedded in the tread on one of the front tires a few weeks ago. Finish nail head, no loss of tire pressure, so not too worried.
Strange thing is that these all season tires seem to ride really well when combined with MSport suspension and DSP (although they don't seem to perform well on ice and snow as far as I can tell).
When it comes time to changing tires, I'll probably go with RFTs again, probably Bridgestone Potenza Pole Position tires, which are rated much higher by X3 owners on TireRack.
2020 X1 sDrive28i l Xline l Luxury l Harman Kardon l Wireless l Parking Assist l Sliding/ Reclining Rear Seat
SOLD - 2013 X3 35i l BSM l MSport l DHP l Premium l Sound l Tech l CW/CWII l Apps l 35% Tint
SOLD - 2010 E92 335 X-drive l BSM l MSport l Steptronic l Premium l CW l Logic 7 l Confort l Nav l KW-V1s l 35% Tint
      05-18-2016, 02:11 AM   #14
squeaky
Drives: 330i
There's another thread discussing the Bridgestone RE960AS. We've been happy with ours, even though it's a runflat.
      05-18-2016, 07:29 AM   #15
Jordster
Wow... 30k miles and still 25-40% left! Do you drive really gently? I don't have the M-sport suspension or DHP, and I drive gently 95% of the time.
I don't know about other RFT, but I think the LS2s are awful. You can feel the crappiness of the tires when you steer away from center. I also didn't realize just how harsh they were until I put on the snows and the car became so much smoother over bumps and less finicky around center.
I have an appointment tomorrow and I'm putting a new set of Conti ExtremeContact DWS 06 (performance all-seasons, not run flat). I'll report back when I have some impressions of that new tire.
      05-18-2016, 08:07 AM   #16
Greg2010
Greg2010's Avatar
The X3 has been my daily driver up until about 6 months ago....primarily used for driving back and forth to work in semi-congested traffic...and with the family over the weekends...so I'd say it had been driven pretty gently (70% comfort; 30% sport mode). I typically use manual shifting as well.
I too am surprised how well the LS2s have held up (and as I said, the harshness of the tires seems to be dampened out with DSP/MSport suspension).
      05-20-2016, 08:31 AM   #17
Jordster
For what it's worth, I just replaced the run-flats with some high quality, high performance, non-RTF all season tires (Conti ExtremeContact DWS 06) and it feels like I cured the car of a disease. It's an incredible upgrade - the car is both smoother AND gripper, quieter and more comfortable.
I can't believe BMW put these crap tires on the car to begin with. Worse still, I can't believe how many of you are convinced that the LS2s are perfectly good tires. They aren't. They are ruining your $50k luxury ride.
      05-20-2016, 11:23 AM   #18
Pinewood
Pinewood's Avatar
I had a similar experience on my E60, but that had space for a space saver. The F25 doesn't!
As discussed on another thread, i will arm myself with slime, compressor, phone, AA and credit cards
When going somewhere alone and far - carry one of my 17" winter run flats.
      05-22-2016, 10:32 AM   #19
BatteryPowered
Drives: Coupe
Slime is not the answer. What you need are pliers and plug kit. Been replacing run flats with regular tires on BMW for 5 years now. Had a blow out on highway, sidewall cut, regular flats etc. Nothing that can't be fixed with plug kit.
I replaced stock runflats on X3 first week of ownership with performance all season tires. Makes ride much smoother and controllable. Each tire is 5-6lbs lighter too.
      06-02-2016, 06:43 PM   #20
lukeeesteve
Drives: A hertz rental car
I could not agree more. The LS2 tires are an older generation run flat and beat the crap out of your kidneys on relatively small road imperfections.
I have replaced them with one of the stiffest sidewall non runflat tires (Yokohama avan v105) and these tires glide over over imperfections I used to avoid. handling performance is definitely up a notch or 2 with these new tires.
