06-18-2011, 05:51 PM | #1 |
Rep 1,560
How cold is your AC?
Just wondering if mine is normal. When is it set on 60 it is cold but not super cold. I have to turn up the blower to the second highest setting to start to make any type of difference & keep it at that to maintain a comfortable feel in the car. I think if I lived in the South, I would have to have it on the highest setting and don't think it would do a very good job. Thank god I'm in the Mid-West. When the temp is on 73 with the AC on, warm air is actually blowing out. When I was in a 3 series loaner this week, the car was at 74 with the AC on and it was coming out COLD! Which is messed up, the X3 or the 3 series?? Is the AC on the X3 just not that great?
06-18-2011, 06:00 PM | #4 |
Rep 3,855
Not had much need to use mine yet but when I tested it out I thought it wasn't as cold as my last car.
06-18-2011, 06:33 PM | #5 |
Rep 12,276
I haven't used mine a lot yet, but will be soon. I have found that with most cars (have had all BMWs for the past 7 years) the closer the outside temp is to the setting, the harder it is to really feel the difference. That said, I don't think the A/C in the X5 or X3 are as effective as the 3 Series. Could be that they have a similarly rated system and too much extra cabin to cool... dunno.
But if you really have a concern, I agree that you should raise the question to the dealer and ask them to check the system. It could be under-charged with coolant. BTW - you are in MI - why do you need A/C? On my annual August trip there I always pack a sweatshirt.
I think it is bad luck to be superstitious |
06-18-2011, 07:10 PM | #7 |
Rep 424
Mine works fine.
We’ve had humid days in the 90’s with heat index’s well over 100 and yes on those days I turn the fan a bit higher, but ride in comfort. It doesn't blow super cold, but cools off the car nicely. Is the dial on the dash set to "blue" Have you tried to recirculate the air? Have you tried the Max? So far I haven’t needed them, but it may help. |
06-18-2011, 07:25 PM | #8 | |
Rep 1,560
06-18-2011, 07:27 PM | #9 | |
Rep 1,560
06-18-2011, 09:00 PM | #10 |
Rep 157
06-18-2011, 09:19 PM | #11 |
ATAP
Rep 165
I live in North Texas where it has been over 100 the past few days and the X3 AC is doing just fine. Cannot get TOO cold in the afternoons, but it does at night when it is still in the 90s outside (ugh).
06-18-2011, 09:36 PM | #12 |
Rep 1,876
Used it on 100 degree humid days and it works well. Blows cold air when set at 70 when it's hot out. If the car was in the sun it takes a bit to kind of stabilize the internal temp, but it quickly produces enough air to make it comfortable. Seems to do that faster at speed vice stop and go traffic.
06-18-2011, 10:41 PM | #13 |
Rep 1,041
Mine is just barely adequate. On a recent 93 deg. F. day it was barely able to keep the car cool with the temp. setting at 70 deg.. F. This was in traffic with engine revs mostly below 1600 rpm. with the A/C set to recirculation mode. At engine speeds of 2K or more, there's plenty of cooling. Our Subaru LGT will cool down to the set temp in 1/3rd the time of the X3 under similar driving conditions.
06-18-2011, 11:38 PM | #14 | |
Rep 1,560
06-19-2011, 12:29 AM | #15 |
Rep 532
So what about heating
Yes we do have hot days in Scotland but I will be more concerned with the heater! Currently a pleasant 8'C here at 06:30, which is chilly for June but ideal for snuggling with the wife.
06-19-2011, 06:37 AM | #17 |
Rep 169
Drives: 2023 X5 45e blue/cognac
I have found that the Ac works really well and quickly when I hit the auto button. Give that a try.
06-19-2011, 06:53 AM | #18 |
Rep 12,276
Nope. Callhoun County... but it depends on which end of August. This year it will be early in the month, so I doubt I'll need it. Though we spend a lot of evening on the water (lake) and it can get a bit chilly. By the end of August you can really feel fall coming.
06-27-2011, 11:03 AM | #19 |
Rep 3,855
Changed my mind on the A/C after today. Temperature was up to 30C here today and I set it to max and it was like ice pretty quickly, then switched to auto and it kept the car at a good comfortable temp
06-27-2011, 09:26 PM | #21 |
Rep 1,876
Max on the lowest setting? Max is max, there are no settings. Any changes and it's off max to manual. When on auto you can set the general fan speed to one of five levels. If too loud, press the fan down button to change the fan speed. Max is the loudest option. It sets the fan to high, routes all air to the middle vents, and sets the car to recirculate. auto is really tecway to go except when you need a serious burst of cooling -- just entered hot car, sitting in sun on hot day, dogs just in from a run . . .
06-28-2011, 01:28 AM | #22 |
Rep 579
I actually find the AC to be too cold at 60 F (lowest possible temp) with the rolling switch turned to blue at the 1 bar setting. It must be broiling where some of you guys are living if max AC isn't cold enough, I personally haven't gone above 2 bars.
Didn't want to make a new thread since my question somewhat relates to the discussed topic. Does anyone notice a moist and musty smell when just simply leaving the car at a temperature without AC on? The moist air goes away when turning on the AC but quickly returns when off so I'm essentially forced to leave it on all the time. Thanks in advance |
