      05-21-2013, 06:26 PM   #1
bazan
Drives: 2014 328GT Sport
2013 X3 Canada 1st service questions
Hi,m
I am bringing my 2013 X3 2.8 in for the first service @ 34,000 km
I have the following questions (esp for those in Canada)
- Any TSB that you guys know that should be applied?
- Last time I was in trying to get service to enable "last use" settings so as to diable "start/stop", service advisor said they cannot do. Anyone else tried?
- For some reason my front rim is peeling off near where the rim meets the tire. I don't think it is a curb rash... if it is then it is spreading.... anone think it is worth while to claim for warranty.. if they accept...any similar issues?
- Anyone successfully get them to custom code some of the settings (ie other than those in idrive)... I don't even know what are the options but if someone can share that would be great.
- Anything else needs to make sure to get them to do in the first service?
Thanks in advance
      05-21-2013, 07:04 PM   #2
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Start stop is available under a Technical Bulletin. They won't be able to code anything else for you.
      05-21-2013, 08:03 PM   #3
bazan
Thanks pokerface...
did you successfully requested them to change that option for you?
Also I believe we still cannot get them to program to remember "sport mode"?
Txs
      05-21-2013, 08:19 PM   #4
pokerface
pokerface's Avatar
Nope. My wife doesn't drive it enough to be bothered with the coding.
