      11-20-2020, 01:10 PM   #1
hbn61013
Drives: 2014 328i, 2014 X3, 1984 E30
Black Brick Behind Rear Differential
Hi Folks
Does anyone know what this black piece of metal is? it is behind the rear differential on my 2014 X3xdrive28i and it is leaking some clear oil. Should I be concerned? And can I use this part to jack the rear?
https://postimg.cc/DWG65Br0
thanks,
      11-20-2020, 01:54 PM   #2
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
Part #13, vibration absorber. Do not use it as a jack point. FCP Euro has them for sale.
https://www.realoem.com/bmw/enUS/sho...diagId=33_1576
dtox9336.00
      11-20-2020, 02:14 PM   #3
hbn61013
Thanks for the response, Najnad. can I leave it with a leak? I suppose it won't harm the car too much. Or am I wrong?
Can I jack from this circle part of the subframe?
https://postimg.cc/ykTTG1nZ
      11-21-2020, 11:50 AM   #4
383vett
383vett's Avatar
Why not use the jackpoints on the frame rail?
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      11-21-2020, 01:00 PM   #5
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
One of the approved places is the differential itself. Other places are the 4 jack points along the outside chassis and a point under the front crossmember. You'll see it sticking through the shroud. When I jack using the diff. I like to use a block of 3/4" plywood as a cushion to prevent any damage to the casting.
