      07-04-2019, 06:00 AM   #1
vahihapehe
Drives: BMW F25
Fiscon bluetooth on RADIO Professional without bluetooth
Hi all, on my F25 from 2011 I have the BMW Radio Professional without bluetooth. I've bought the module from Fiscon (code 38975) without the activator they sell.
The BMW Radio Professional is AL2501 with MOST.
I'm just wondering: can I code this with Esys (so without buy the activator from them)? What do I have to change with Esys?
Many thanks in advance to all, have a nice day!
      07-05-2019, 04:39 PM   #2
vahihapehe
Drives: BMW F25
I'm adding more info cause today I've tried some things but for the moment I don't have the full solution.
Starting point: car with BMW Radio Professional (SA Code 663) without bluetooth / with MOST / with Idrive / no button-wheels / no USB port
First step: install fiscon module (code 38975)
Result: bluetooth working on car speaker, microphone ok, music stop when calling, number (not name) displayed in the kombi-instrument, nothing on the CIC (car has no telephone / contacts menu), cannot answer call from idrive (of course)
Second step: connect with Esys and read FA / SVT
Result: these are the SALAPA-Element on the car: 1CA,1CC,1CD,230,240,2K0,2PA,465,4CG,508,520,534,54 8,663,698,845,855,884,8KA,8S1,8TL,8TM,925
Third step: edit FA adding SA Code 6NH + VO Code CIC
Result: bluetooth working on car speaker, microphone ok, music stop when calling, NO number displayed in the kombi-instrument, telephone / contact MENU on the CIC (it display name of paired devices, but goes in "please wait" loop), cannot answer call from idrive
Fourt step: check changes on HU CIC ECU
Result: these fields have been modified
3000 HMI
CDMM_AUX_HU Left: aktiv (Active) = 01 Right: nicht_aktiv (not active) = 00
3001 EXBOX
USB_AVAILABLE Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
FBM_TEL Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
3003 TELEFON TELEMATIK ONLINE
PHONE_TYPE Left: no_phone (No phone) = 00 Right: inbox_champ2 = 04
VCARD_OVER_MOST Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
PHONE_ALL_INC_CALLS_LIST Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
PHONE_MPC Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
CDMM_USB_AUDIO_SINGLE Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
MICROPHONE Left: no_microphone = 00 Right: one_microphone_under_car_roof = 03
ADRESSBOOK Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
PHONE_CONFERENCE_CALL Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
API_TYPE Left: none (None) = 00 Right: inbox_microsoft (Inbox microsoft) = 04
BT_MODUL_ON_OFF Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
AUDIO_PLAYER_ON_OFF Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
EXTERNAL_CALL_LISTS Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
MICROPHONE_SENSITIVITY Left: L4_mic = 00 Right: L6_mic = 01
FUNCTIONALITY_VIEWER Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
DATACOM_INTERFACE Left: tcu_mulf (TCU mulf) = 00 Right: inbox (Inbox) = 02
BT_PHONE_INSTANCE_ID Left: wert_0 (value 0) = 00 Right: wert_2 (value 2) = 02
DATACOM_TRANSFER Left: most_high = 00 Right: mamac = 01
CDMM_USB_COMPOSER_IPOD Left: disabled = 00 Right: enabled = 01
CDMM_USB_COMPOSER_MTP Left: disabled = 00 Right: enabled = 01
PHONEBOOK_CACHING Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
ONLINE_DAR_INDEX Left: dar_4 = 04 Right: dar_9 (Dar 9) = 09
NAD_PHONE_INSTANCE_ID Left: wert_0 (value 0) = 00 Right: wert_1 (value 1) = 01
SWUP_SOURCE_USBMSCDD Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
3004 SYSTEM EINSTELLUNGEN
SOFTWARE_UPDATE_MANAGER Left: nicht_aktiv (not active) = 00 Right: aktiv (Active) = 01
In the end:
I've got some opinion on what is correct and what not, but a part from testing each code, I've found this info:
https://www.bimmerfest.com/forums/sh...d.php?t=966607 ---> here is the list of all SA Codes ---> what do I need?
Here someone wrote about the "please wait" loop: https://f30.bimmerpost.com/forums/sh...php?p=23565040 ---> he says it's BT_MODUL_ON_OFF, but maybe I also need something else
      07-26-2019, 02:53 AM   #3
vahihapehe
Drives: BMW F25
I found the solution for this, it's just coding 2 parameter with esys. Result:
- phone in main display with contacts
- phone number in kombi display
If anyone need this, just send a PM
Tags
activator, bluetooth, bmw radio professional, esys, fiscon
