      05-09-2012, 07:32 AM   #1
terrytnt
terrytnt's Avatar
Drives: 2012 X3 35i M/DHP Carbon Black
X3 Performance Software Upgrade
At the first of the year (or late fall 2011) BMW released a 3-Series performance upgrade for the sedan models - heard anywhere from 10-20% performance increase, and yes there is a cost associated with the software upgrade.
Does anyone know the timing for our X3s?
      05-09-2012, 07:37 AM   #2
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Nop, have heard anything about an OEM upgrade.
      05-09-2012, 08:14 AM   #3
n55x3
Drives: n55 BMWs
Are you referring to the 335is which saw a bump to around 320HP?
I'm not sure there is any one component that can show you 10-20% power increase. A 20% bump would put you right around 360 hp at the crank. That is substantial. There are various tunes on the market for the N55 but again I don't think you'd ever see 20% power increase with just a tune alone. You'd need several new parts to reach that goal.
      05-09-2012, 08:44 AM   #4
terrytnt
terrytnt's Avatar
You're correct, I sure I got the range wrong, probably more like a 5-10% increase. The dealership said is was for the 3-Series (no other specifics)
      05-09-2012, 09:01 AM   #5
n55x3
Drives: n55 BMWs
Cool. Like lbigh said, no OEM options to date.
There are some aftermarket options though as the N55 motor is very tuneable.
** and on edit, the 335is actually uses the older twin turbo N54 motor so my example above isn't 100% applicable.
