10-03-2023, 08:41 AM | #1 |
Rep 40
Help with: YELLOW DRL
Hey guys, I was thinking about doing the yellow drl on my 2020 x3m. I was wondering what is involved on installing. I believe the bumper has to be removed, but I see on g80s only the wheel liners have to be removed. I can't seem to find any videos on the topic. I'd also like to buy extra heat fins for the headlights to install the module instead of taking apart the old ones. Any good place to find those? Any little input is greatly appreciated. Thanks guys!
10-03-2023, 09:51 AM | #3 | |
Need mo $$s
833
Rep 885
https://x3.xbimmers.com/forums/showt...ght=yellow+drl There are several threads on this topic, so maybe do a search for some of the others
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
10-03-2023, 10:10 AM | #4 | |
Rep 40
10-03-2023, 11:03 AM | #5 |
Professor
2250
Rep 1,813
Drives: '23 M2 & '22 X3 M Competition
Not related to your how to, but I find it interesting this is now "cool" again. Everybody hated yellow DRLs when they were introduced and couldn't jump fast enough on the white DRL train. Now ppl want to go back to yellow.
10-03-2023, 02:03 PM | #7 |
Rep 40
I think its mainly because of the CSL having them, but definitely inderstandable
10-04-2023, 02:53 AM | #8 |
Rep 2,067
10-04-2023, 09:42 AM | #9 |
Rep 190
10-04-2023, 09:44 AM | #10 |
Rep 2,067
ocdx30.00 gofastbmw5100.00 |
10-07-2023, 10:45 PM | #12 |
Rep 2,067
10-13-2023, 01:16 PM | #13 |
Rep 190
10-13-2023, 03:19 PM | #14 |
Rep 2,221
10-15-2023, 10:51 PM | #15 |
Rep 2,067
10-16-2023, 11:47 AM | #16 |
Rep 190
Not sure how this pic will help but I really didn't feel like removing all the covers and stuff to show it 100% . You can see from the pic that I cut off enough of the plastic to remove it .
Removed the black bracket that holds the hood bump stop Removed the 3 T25 (I think) bolts holding the module Cut away enough of the plastic headlight housing to be able to pull the module back away from the headlight and up enough to unplug it to completely remove it . The unplugging of the module was IMHO the hardest part . I could have cleaned up the part I cut off a little better but didn't really care too much since the plastic covers hide enough to where not many people would notice . Swap the boards out and reverse the steps and you are done ! Yes , mine looks ugly from the pics but it's not my DD so I haven't gone back and cleaned everything up . I thought about actually going back and Gorilla taping them so you can't even see where i cut off the black plastic . |
10-16-2023, 01:52 PM | #17 | |
Rep 2,067
I'm sure you had all the right tools, and you seem like a capable DIYer. With that said, i'm going to assume here that you've "exhausted" all options (short of removing bumper and headlight) to do this (i.e. to have enough of clearance to remove/unplug/re-plug/re-insert) "without" that extra cutting. Would i be right about that? Perhaps i am mis-judging just how much clearance i will get after removing the bracket that holds the hood bump stop, because after playing with in my head i came out "thinking" having enough clearance to remove/unplug/re-plug/reinsert. In other words, after removing the bracket that holds the hood bump stop, that helps to clear the space A that blocked that area behind the module, the depth from B is still too long/deep to not able to cleanly remove and unplug the module? Last edited by dinan5m3; 10-16-2023 at 02:14 PM.. |
10-16-2023, 02:27 PM | #18 | |
Rep 190
.......and yes I did have all proper tools ( even had to go buy some extra tools ) and I consider myself a more than capable DIYer . In one of my posts , I showed which ratcheting tool I used for the T20 bolts because the one I originally had would allow the bit to come out the back of the ratchet and I almost lost it down into the engine bay a few times . Found the closed end ratchet at Harbor Freight and it worked great because it's a tight fit between the module and bracket area . It takes a little time and patience but it worked perfect . https://www.harborfreight.com/8-piec...RoCCJgQAvD_BwE |
dinan5m34263.50 |
10-16-2023, 02:31 PM | #19 | |
Rep 190
10-17-2023, 02:51 PM | #20 |
Rep 2,067
You probably already looked at removing the two screws holding the headlight from the top, and ruled that out as worthless?
Looks like the headlight is held in 3 different spots, top, bottom and latch on the side. With the bracket that holds the hood bump removed, removing the 2 screws that hold the headlight from top didn't give (just) enough clearance to "tilt" the headlight to front of the car to create additional room? |
10-18-2023, 11:03 AM | #21 | |
Rep 190
10-18-2023, 02:01 PM | #22 | |
Rep 2,067
But then there is a locking tab (maybe not needed to move the headlight out by an ~1 inch or so) on the side of the headlight that do need front bumper in that area to be loosed. But to loosen that front bumper in that area requires extra trim pics to be first removed. Damn, i could pay someone to go investigate this, (make video) and report back. Interested? Easy $ earned ? EDIT: nm, i don't think the headlight will move out to the front of the car, without the front bumper area that touches the headlight to first come out to the front. urgh... this would be okay if install and forget about it, but i'm fairly certain it's not going to be that lucky, and in time will need to replace the broken module, and go through all this, again Last edited by dinan5m3; 10-18-2023 at 03:08 PM.. |
Tags |
headlights, x3m, yellow drl |
