      02-07-2023, 12:54 PM   #1
SpyrosX
Drives: BMW X3
Swapping headlight housings
I have done the following to my F25 2011. My right Xenon non-adaptive headligth glass broke and used the housing of an adaptive Xenon. I transfered the Driver module, Control unit and the two led modules from the non-adaptive. Everything works except the angel eyes and 800F89 error code appears. Is the wiring the problem? Is there any scematic that spots the differences between non-adaptive and adaptive xenon?
      02-08-2023, 12:32 PM   #2
SpyrosX
Drives: BMW X3
any ideas?
      02-12-2023, 10:20 PM   #3
zhengbob
Drives: BMW e90/e93 2009; F25 2014
I think the main connector wiring is different between non-adaptive vs. the adaptive model. The shape of the housing is identical, but the wires for adaptive vs. non-adaptive are not the same, the adaptive model has more pins in use, and the harness pin assignments are different too.
I did similar thing but the other way -
On my 2013 X3 project car (bi-xenon with AFS headlights), the original headlights are destroyed, so I bought cheaper halogen non AFS headlights, connected, but the ECU even can't recognize it, always throw AFS headlight malfunction code, and the headlights won't light on.
      02-22-2023, 07:16 AM   #4
SpyrosX
Drives: BMW X3
Do you (or anyone else) have the wiring schematics of the right headlight? I want to clarify how I can downgrade the adaptive to non-adaptive.
      04-27-2023, 11:56 AM   #5
SpyrosX
Drives: BMW X3
up
      04-28-2023, 12:40 PM   #6
steaman
steaman's Avatar
Drives: i3S - 2019 X3 3.0d F25 - 2011
I think you find information in this thread; https://x3.xbimmers.com/forums/showthread.php?t=1686412
      05-18-2023, 01:27 PM   #7
SpyrosX
Drives: BMW X3
I am trying to check if the problem comes from short ciruit counter. I am using tool 32 but when trying to reset I have "ERROR ECU REQUEST OUT OF RANGE".
Any suggestions?
      09-29-2023, 10:26 AM   #8
SpyrosX
Drives: BMW X3
I ended up changing the LED modules and the problem solved
