      05-09-2012, 03:22 PM   #1
X3emist
X3emist's Avatar
10
Drives: 2013 X3 M/Sport
Rattle from exhaust on shutdown
On the 28i 2013 I was standing behind ours when it was shut off and noticed a funny rattle from what sounded like just inside the exhaust tips. This has replicated every time I have listened for it. Some previous X3's had a flapper valve of some sort up inside the end of the exhaust which may be the cause.
Could any of you guys with 13 28i's see if you can replicate the issue.
2013 X3 Msport, White/Black Montana, M-Sport/Prem Pkg, Dynamic Handling, Xenons, Cold Weather, HU, Prem Stereo
      05-10-2012, 07:06 AM   #2
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
That would be the flapper valve. You can disable it by unplugging the exhaust solenoid in the left side wiring compartment of your trunk.
      05-10-2012, 06:54 PM   #3
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
The engine makes noise...you can turn it off by hitting the start/off button. Sorry had to say that.. If its normal, why mess with things. If its not, thats what the warranty is for!
      05-10-2012, 08:45 PM   #4
X3emist
X3emist's Avatar
10
Interesting, I'll have to investigate further. The flapper valve has been around since at least 2006. The funny thing is, our 06 X3 doesn't have it while others have reported that they have one. I'll report back. Shutting the engine off isn't an option, don't wanna lose the fun factor of the ULTIMATE DRIVING MACHINE!!!!!!!!!!
      05-11-2012, 02:24 PM   #5
Beyu
Drives: 135i
I would think it's the flapper valve also but this doesn't seem to be the case, unless they changed the exhaust system for the new 28i with the turbo inline 4. If your 28i does in fact have a valve on the exhaust you can unplug the rubber cord and this should fix it like Juddholland said.
The reason why one might want to unplug it would be to remove that metallic clicking sound and to make the exhausts a little louder during idle and low rpms. There's no negative consequences from doing it and it's a free way to make your exhaust louder in literally 2 minutes which Judd along with myself have both done.
Here's a pic of what the two exhaust systems look like :
