      06-27-2015, 10:29 AM   #1
Mr Comfort
Owner/ Operator
Drives: 2012 x3 35i
2012 X3  [0.00]
TPMS problems with wheel change
Hey folks, I picked up some 20 inch staggered 310's off a 2015 x3. I had square 19 inch 309's that will be for my winter wheels. Tpms will not read the 2015 sensors.
Is this a code problem with the staggered tires? Or do I need different tpms in the rims?
I was reading that both years use the same frequency but the stems or antenna's are different.
Replacing the stems are only fourteen bucks each but new sensors are a different matter. Anyone have any thoughts or experience with this?
      06-27-2015, 11:48 AM   #2
Tjalle
Drives: X4 35i
I have staggered 310:s as summer tires. I bought 18" winter tires from local tireshop - Conti Contact with studs - they programmed pirate TPMS to fit X4, and after calibration in my car they worked.
      06-27-2015, 01:24 PM   #3
Mr Comfort
Owner/ Operator
Drives: 2012 x3 35i
2012 X3  [0.00]
I guess my real question is getting 2015 tpms units to work on a 2012. Is it doable
      06-27-2015, 01:35 PM   #4
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
You tried resetting?
      06-27-2015, 02:16 PM   #5
Mr Comfort
Owner/ Operator
Drives: 2012 x3 35i
2012 X3  [0.00]
Yes of course, i drive states tpms malfuction.
      06-27-2015, 11:57 PM   #6
02420X3
Drives: 2011 X3 35i
I'm away from my PC or I would go this for you, but check realoem.com to see if the part numbers are the same for the TPMS sensors on both model years. If they are, then you likely have a bad TPMS sensor.
      06-28-2015, 04:52 AM   #7
Mr Comfort
Owner/ Operator
Drives: 2012 x3 35i
2012 X3  [0.00]
rats, different module hopefully be able to sell them
      06-28-2015, 08:57 AM   #8
///Mposter
Macgyver
///Mposter's Avatar
Yeah, sorry I had to ask about the reset. Well new aftermarket tpms goes for $25-$55 each ( non BMW stamped but same part). I'm sure you could make your money back easily by selling to a fellow member. They last about 5 to 7 years. One on my wife's Acura just went out last week and its about 7 years on the dot. I'm probably just going to replace all 4 so I don't have to see the display lit up again.
      06-29-2015, 07:19 AM   #9
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
2 possible outcomes.
1. sensors are not compatible 2012 vs 2015, there is no signal or communication between TPMS and sensors.
2. maybe during installation, sensors were damaged giving a malfunction errror
      06-30-2015, 04:32 AM   #10
Mr Comfort
Owner/ Operator
Drives: 2012 x3 35i
2012 X3  [0.00]
2015 are different sensors I will have four for sale shortley
