      11-17-2017, 10:11 AM   #1
batlin
batlin's Avatar
43
Drives: BMW X5
Removed
Removed
      11-23-2017, 04:52 AM   #2
02420X3
Drives: 2011 X3 35i
Have the dealer or a good indy check the Transfer Case fluid. If they find metal shavings then it will need to be replaced. The cost will be $3000+ for the dealer to replace it.
      11-25-2017, 05:53 PM   #3
brissim
Drives: X3 30d (2011 F25) - now sold
First try simply flushing the transfer case. We had similar-sounding symptoms on our F25 a couple of years ago on two occasions. A flush of the transfer case (at that time carried out under warranty) solved the problems.
Tony
      11-29-2017, 08:43 AM   #4
jman103099
Drives: 2011 E90 & 2011 F25
Same thing happened to me, I thought I already posted this on someone elses thread, but that might have been on the "other" X3 forum. There's a SIB out there for a transmission reprogram for the 2011s which your dealer should be able to find. Basically, the tranny gets confused and shifts between 2-1-2, or 2-3-2 and causes that jerkyness at low speed. I believe the SIB even specifically says something about when the wheels are turned.
Happened to my car and was HORRIBLE. Got the transmission re-programmed at the dealer and it was fine for 65k miles (I sold the X last month).
Good luck!
      11-29-2017, 08:55 PM   #5
GGEVOX
Drives: G01 M40i, F36 440xi
lol, was it a deep sea blue?
I just picked up a higher milage that has an awful hesitation at low speeds. I fear the worst. I will see if an update will help.
      11-30-2017, 08:04 AM   #6
jman103099
Ha, no. Sold it to someone who flew down from Oregon to Arizona. My car was honestly right near perfect.
Seriously, try the transmission reprogram. Ask the dealer to research the SIBs on it. I remember the other thing that would happen is when I'd come near a stop, slowing down but not stopping all the way, then try to accelerate the car would lurch forward or not go at all. This is also when the dealer (and SIB) said it was going from 2nd to 1st to 2nd all within a second or two. I could tell the reprogramming worked by driving the 5 miles home from the dealer.
      12-06-2017, 10:06 AM   #7
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
When is it recommended to change the transfer case fluid?
      12-10-2017, 08:26 PM   #8
ba ba boosh
Drives: Jalopy
BMW says never, but usually 80-100k mile mark.
      01-08-2018, 02:45 PM   #9
jman103099
50 bucks for the fluid from BMW and I paid an indy about 60 to do mine. The hard part is that the exhaust is in the way of the drain hole and I dont have all the tools in the world to get to that point. Apparently you can do it with a box wrench and large hex bolt or something, but I was ok paying someone to do it.
My last X3 (2006) I didnt even have to raise the car, just crawled under and drained and filled.
